UV Map problem in Octane!
Forums: UV Map problem in Octane!
Sub forum for help and tutorials.
Moderator: JimStar
Postby brianbrook » Wed Mar 01, 2017 3:52 pm
brianbrook Wed Mar 01, 2017 3:52 pm
What are the steps to get add a UV map assigned to an obj. file in Maya 2014 using the 1.20 plugin...it works in Mental Ray but I can't find a way in Octane!
brianbrook
Re: UV Map problem in Octane!
Postby calus » Wed Mar 01, 2017 8:09 pm
calus Wed Mar 01, 2017 8:09 pm
brianbrook wrote:What are the steps to get add a UV map assigned to an obj. file in Maya 2014 using the 1.20 plugin...it works in Mental Ray but I can't find a way in Octane!
hmm, the 1.20 plugin was released almost 4 years ago, to be honest I don't remember at all if it was working the same way as now.
I found this topic : viewtopic.php?f=28&t=33685
But adding an UV map is not done with the plugin, it's done with builtin Maya tools, look in Polygons/UV menu to apply any projection to UVs.
Or if you want to use a texture projection (spherical, box , ...) but then you are not using the UVs but projecting the texture,
in the current plugin it's done by adding a projection node in the imageTexture node, don't know if it was supported at this time.
Pascal ANDRE
calus
Return to Help / Tutorials
Sat Apr 27, 2024 12:51 am [ UTC ]
