Modified Batch render script - help needed
Forums: Modified Batch render script - help needed
Postby TheImageFaculty » Wed Aug 24, 2016 12:07 pm
TheImageFaculty Wed Aug 24, 2016 12:07 pm
I'm altering the batch render script (hope this is allowed), so it does the following in order to work with Thinkbox Deadline and needs no input from the GUI:
Constant output location DONE
OCS file name as sub folder name DONE
Constant output filename (based on the standard pattern) DONE
Constant output file type DONE
A workaround so no-one has to press the "Start" button NEEDS HELP
A workaround so the dialog closes when the render has finished NEEDS HELP
Cheers,
Henrik Mark
The Image Faculty ApS
https://theimagefaculty.com
TheImageFaculty
Re: Modified Batch render script - help needed
Postby calus » Wed Aug 24, 2016 12:56 pm
calus Wed Aug 24, 2016 12:56 pm
In my modified version, the output window does not display at all so no need to press start or close, should work for yu:
myBatchRender.lua
(23.16 KiB) Downloaded 950 times
Pascal ANDRE
calus
Postby Phantom107 » Sun Apr 15, 2018 1:48 am
Phantom107 Sun Apr 15, 2018 1:48 am
Many thanks for making this!
edit, this throws an error message in Octane 3.08... any fix?
edit2, okay now its works. Weird, something in the node structure threw it off but I don't know what
Phantom107
Return to Lua Scripting
Users browsing this forum: No registered users and 30 guests
Fri Apr 26, 2024 5:57 pm [ UTC ]
