Page 1 of 2
Scripted node graph to extract camera position
Posted: Sun Aug 23, 2015 3:24 am
by manalokos
Hello
I've been trying to make a scripted node graph to extract camera position and target position or other values as outputs.
This way I can connect an alembic camera to this scripted operator and connect the output nodes to a new camera where I can control the aperture.
But as I have no experience in programming in LUA for octane, I was only able to create an input and output for the nodes, but the connections I wasn't able to make.
Could someone show me how to do this?
Kind regards
Filipe
Re: Scripted node graph to extract camera position
Posted: Sun Aug 23, 2015 5:15 am
by Goldorak
Thomas made one for me. I can look for it and post it here once I locate it...
Posted: Sun Aug 23, 2015 5:28 pm
by manalokos
Thanks Goldorak
Meanwhile I'll keep trying.
Posted: Sun Aug 23, 2015 8:36 pm
by manalokos
I spent the whole afternoon trying to make this work, finally I was able to get the results I was expecting...
The output shoud be a camera node but meanwhile I can connect the position, target, and focus distance to a secondary camera...
It has 2 inputs, one for the alembic camera, and another for another alembic camera to work as a focus point. It would be great if alembic import would get position of nulls into float output...
    local Aextract = {}
    local inputs, tex
    -- onInit function, this is called once in the beginning.
    function Aextract.onInit(self, graph)
        -- input and output infos
        local inputInfos = {
            {type=octane.PT_CAMERA, label="camara", defaultNodeType=octane.NT_IN_CAMERA},
             {type=octane.PT_CAMERA, label="foco", defaultNodeType=octane.NT_IN_CAMERA}
        local outputInfos = {
            {type=octane.PT_FLOAT, label="pos"},
            {type=octane.PT_FLOAT, label="target"},
            {type=octane.PT_FLOAT, label="focusdistance"}
        -- use these functions to set up input and output linkers. This will keep
        -- existing linkers so existing connections in the parent graph are kept.
        inputs = graph:setInputLinkers(inputInfos)
        local outputs = graph:setOutputLinkers(outputInfos)
        -- set up a node to give the graph some output value
        posnode = octane.node.create{ type=octane.NT_FLOAT, name="posicaocamara", graphOwner=graph }
        targetnode = octane.node.create{ type=octane.NT_FLOAT, name="posicaotarget", graphOwner=graph }
        targetvector =  octane.node.create{ type=octane.NT_FLOAT, name="pontodefoco", graphOwner=graph }
        focusdistance = octane.node.create{ type=octane.NT_FLOAT, name="distanciadefoco", graphOwner=graph }
        outputs[1]:connectTo("input", posnode)
        outputs[2]:connectTo("input", targetnode)
        outputs[3]:connectTo("input", focusdistance)
        self:setEvaluateTimeChanges(true)
    end
    function Aextract.onEvaluate(self, graph)
        local camara = inputs[1]:getInputNode("input")
        local posicao = camara:getPinValue("pos")
        local foco = inputs[2]:getInputNode("input")
        local target = foco:getPinValue("pos")
        print(posicao[1], posicao[2], posicao[3])
        posnode:setAttribute("value", posicao)
        targetnode:setAttribute("value", target)
        targetvector:setAttribute("value", {target[1]-posicao[1], target[2]-posicao[2], target[3]-posicao[3]})
        focusdistance:setAttribute("value",{ math.sqrt(math.pow((target[1]-posicao[1]),2)+math.pow((target[2]-posicao[2]),2)+math.pow((target[3]-posicao[3]),2)),0,0})
        print(math.sqrt(math.pow((target[1]-posicao[1]),2)+math.pow((target[2]-posicao[2]),2)+math.pow((target[3]-posicao[3]),2)))
      return true
 end
    return Aextract
Posted: Mon Aug 24, 2015 9:18 am
by bepeg4d
here is my attempt but with just one input abc node:
FromABC2Thin.orbx
(4.21 KiB) Downloaded 1740 times
It takes the focal distance from the abc node and I had to add also the focal length for correctly matching between the two cameras.
It should work also with animated camera ;)
ciao beppe
local ABC2ThinScript = {}
local mInput
local mOutputF
local mOutputD
local mOutputP
local mOutputT
function ABC2ThinScript.onInit(self, graph)
    -- create input linkers
    local inputs = graph:setInputLinkers
            type            = octane.PT_CAMERA,
            label           = "ABCcam",
            fromNodeType    = octane.NT_OUT_CAMERA,
            fromPinId       = octane.P_INPUT
    mInput = inputs[1]
    -- create output linkers
                type = octane.PT_FLOAT,
                label = "ABCfocal_length"
                label = "ABCfocal_depth"
                label = "ABCposition"
                label = "ABCtarget"
    -- create float value node that will provide the ABC Camera value
    mOutputF = octane.node.create
        type         = octane.NT_FLOAT,
        name         = outputs[1].name,
        pinOwnerNode = outputs[1],
        pinOwnerIx   = 1
    mOutputD = octane.node.create
        name         = outputs[2].name,
        pinOwnerNode = outputs[2],
        pinOwnerIx   = 1
    mOutputP = octane.node.create
        name         = outputs[3].name,
        pinOwnerNode = outputs[3],
        pinOwnerIx   = 1
    mOutputT = octane.node.create
        name         = outputs[4].name,
        pinOwnerNode = outputs[4],
        pinOwnerIx   = 1
end
function ABC2ThinScript.onEvaluate(self, graph)
    local inCam		= mInput:getConnectedNode(octane.P_INPUT)
    if inCam == nil then
    local inABC		= nil
    local inFov	 	= nil
    local inDpt	 	= nil
    local inPos	 	= nil
    local inTarg 	= nil
    elseif inCam ~= nil then
    local inABC		= inCam:getConnectedNode(octane.P_INPUT)
    local inFov	 	= inABC:getPinValue(octane.P_FOCAL_LENGTH)
    local inDpt	 	= inABC:getPinValue(octane.P_FOCAL_DEPTH)
    local inPos	 	= inABC:getPinValue(octane.P_POSITION)
    local inTarg = inABC:getPinValue(octane.P_TARGET)
    mOutputF:setAttribute(octane.A_VALUE, inFov)
    mOutputD:setAttribute(octane.A_VALUE, inDpt)
    mOutputP:setAttribute(octane.A_VALUE, inPos)
    mOutputT:setAttribute(octane.A_VALUE, inTarg)
    ABC2ThinScript:setEvaluateTimeChanges(true)
	end
end
return ABC2ThinScript
Posted: Mon Aug 24, 2015 10:14 am
by manalokos
Wow, so much different way to write the code...
There are so few examples of Lua scripted graphs that is difficult to learn.
This is good, but the software I use won't export the focus distance so I had to make the double camera hack.
Posted: Mon Aug 24, 2015 12:37 pm
by bepeg4d
hi,
this is my second scripted graph and probably my approach is not the best, better to wait for the Thomas' example for a correct reference ;)
ciao beppe
Posted: Wed Dec 09, 2015 2:57 am
by prehabitat
Did Thomas' script ever turn up?
Posted: Wed Dec 09, 2015 3:13 am
by stratified
I think it's this one. If you want to inspect/modify the script you need to enable "Scripted graph development" in the application preferences.
camera-explode.orbx
(100.3 KiB) Downloaded 1722 times
cheers,
Thomas
Posted: Thu Dec 10, 2015 6:43 am
by prehabitat
Cheers :D
