alembic camera import: aperture settings
Forums: alembic camera import: aperture settings
Postby ekoja » Wed Jun 25, 2014 1:56 pm
ekoja Wed Jun 25, 2014 1:56 pm
Does anyone know how I'll go about writing a script to set the aperture of an alembic camera import to zero?
I've noticed that when i import an animated camera into octane the objects are out of focus and this is especially troublesome when the objects are moving to and from the camera. I'd like to keep everything in the scene in focus and add depth of field in later in post.
I'll be happier if someone could write such a scrip for me as i know very little about lua scripting.
Win 7x64|Geforce GTX Titan|i7 3930k|48GB RAM
ekoja
Re: alembic camera import: aperture settings
Postby kavorka » Wed Jun 25, 2014 3:50 pm
kavorka Wed Jun 25, 2014 3:50 pm
The alembic aperture is set when you export. You will need to change the aperture of your camera in your host app.
kavorka
Postby ekoja » Wed Jun 25, 2014 9:41 pm
ekoja Wed Jun 25, 2014 9:41 pm
i did that, nothing changed.
On maya camera attributes there are two boxes right of the camera aperture label, the first one changes the field of view the other does nothing and the aperture setting on the octane tab has no effect on the exported camera.
Which setting do i change to eliminate depth of field when i import a camera into octane?
ekoja
Postby kavorka » Wed Jun 25, 2014 10:25 pm
kavorka Wed Jun 25, 2014 10:25 pm
Hmm, I don't know about the Maya exporter. For me, I need to make sure my camera has zero aperture before I export the alembic file. If it is still exporting the aperture, ask in the Maya forums, it may be a bug or there might be something else you need to check. As far as I know, there is no way to change the aperture of an alembic camera in Octane.
kavorka
Return to Lua Scripting
Users browsing this forum: No registered users and 29 guests
Fri Apr 26, 2024 12:12 pm [ UTC ]
