Panel stack example script
Forums: Panel stack example script
Postby stratified » Thu Jan 16, 2014 8:07 pm
stratified Thu Jan 16, 2014 8:07 pm
Hi all,
Just a quick example on how to use the panel stack in Lua. I modified the user interface of the turntable animation to use a panel stack. Panel stacks come in handy when you have a lot of stuff to display on a single window. The panel stack component reveals a scroll bar when the components don't fit.
Panel stacks are similar to groups they take a list of child components and when you don't explicitely set the width and height, they take the dimensions of their largest child component. They take 2 extra lists open with the initial open-close stated for each child and captions with the caption to appear above each child component. Here's how to create a panel stack:
-- stack that puts all in place
local panelStack = octane.gui.create
    type     = octane.gui.componentType.PANEL_STACK,
    children =
        settingsGrp,
        fileGrp,
        progressGrp,
        buttonGrp
    open     = { false, false, false, false, },                     -- component open or closed
    captions = { "Settings", "File Output", "Progress", "Buttons" } -- captions to appear above the children
Here's a full working example:
-- Example on how to use the panel stack
-- @description Panel stack example
-- @version     0.1
-- @author      Thomas Loockx
-- creates a text label and returns it
local function createLabel(text)
    return octane.gui.create
        type   = octane.gui.componentType.LABEL,    -- type of component
        text   = text,                              -- text that appears on the label
        width  = 100,                               -- width of the label in pixels
        height = 24,                                -- height of the label in pixels
end
-- creates a slider and returns it
local function createSlider(value, min, max, step, log)
        type        = octane.gui.componentType.SLIDER, -- type of the component
        width       = 400,                             -- width of the slider in pixels
        height      = 20,                              -- height of the slider in pixels
        value       = value,                           -- value of the slider
        minValue    = min,                             -- minimum value of the slider
        maxValue    = max,                             -- maximum value of the slider
        step        = step,                            -- interval between 2 discrete slider values
        logarithmic = log                              -- set the slider logarithmic
end
-- helper to pop-up an error dialog and optionally halts the script
local function showError(text, halt)
    octane.gui.showDialog
        type  = octane.gui.dialogType.ERROR_DIALOG,
        title = "Turntable Animation Error",
        text  = text,
    if halt then error("ERROR: "..text) end
end
-- lets create a bunch of labels and sliders
local degLbl       = createLabel("Degrees")
local offsetLbl    = createLabel("Start Angle")
local targetLbl    = createLabel("Target Offset")
local durationLbl  = createLabel("Duration")
local frameRateLbl = createLabel("Framerate")
local frameLbl     = createLabel("Frames")
local samplesLbl = createLabel("Samples/px")
local degSlider       = createSlider(360, -360 , 360, 1, false)
local offsetSlider    = createSlider(0  , -180 , 180, 1, false)
local targetSlider    = createSlider(10 , 0.001, 10000, 0.001, true)
local samplesSlider   = createSlider(400, 1 , 16000, 1, true)
-- these sliders are couples (25 frames @ 25 fps is 1 second of animation)
local durationSlider  = createSlider(1 , 1 , 3600  , 0.001, true)
local frameRateSlider = createSlider(25, 10, 120   , 1    , false)
local frameSlider     = createSlider(25, 10, 432000, 1    , true)
-- manual layouting is tedious so let's add all our stuff in a group.
local settingsGrp = octane.gui.create
    type     = octane.gui.componentType.GROUP,  -- type of component
    text     = "Settings",                      -- title for the group
    rows     = 7,                               -- number of rows in the grid
    cols     = 2,                               -- number of colums in the grid
    -- the children is a list of child component that go in each cell. The cells
    -- are filled left to right, top to bottom. I just formatted the list to show
    -- where each component goes in the grid.
    children =
        degLbl           , degSlider       ,
        offsetLbl        , offsetSlider    ,
        targetLbl        , targetSlider    ,
        durationLbl      , durationSlider  ,
        frameRateLbl     , frameRateSlider ,
        frameLbl         , frameSlider     ,
        samplesLbl       , samplesSlider   ,
    padding  = { 2 },   -- internal padding in each cell
    inset    = { 5 },   -- inset of the group component itself
-- file output
-- create a button to show a file chooser
local fileChooseButton = octane.gui.create
    type     = octane.gui.componentType.BUTTON,
    text     = "Output...",
    width    = 80,
    height   = 20,
-- create an editor that will show the chosen file path
local fileEditor = octane.gui.create
    type    = octane.gui.componentType.TEXT_EDITOR,
    text    = "",
    x       = 20,
    width   = 400,
    height  = 20,
    enable  = false,
-- for layouting the button and the editor we use a group
local fileGrp = octane.gui.create
    text     = "Output",
    rows     = 1,
    cols     = 2,
    children =
        fileChooseButton, fileEditor,
    padding  = { 2 },
    inset    = { 5 },
-- progress bar
-- eye candy, a progress bar
local progressBar = octane.gui.create
    type   = octane.gui.componentType.PROGRESS_BAR,
    text   = "render progress",
    width  = fileGrp:getProperties().width * 0.8, -- as wide as the group above
    height = 20,
-- for layouting the progress bar
local progressGrp = octane.gui.create
    text     = "",
    rows     = 1,
    cols     = 1,
    children = { progressBar },
    padding  = { 10 },
    centre   = true,    -- centre the progress bar in it's cell
    border   = false,
-- render & cancel buttons
local renderButton = octane.gui.create
    text   = "Render",
    width  = 80,
    height = 20,
local cancelButton = octane.gui.create
    text   = "Cancel",
    width  = 80,
    height = 20,
local buttonGrp = octane.gui.create
    text     = "",
    rows     = 1,
    cols     = 2,
    children = { renderButton, cancelButton },
    padding  = { 5 },
    border   = false,
    children =
        settingsGrp,
        fileGrp,
        progressGrp,
        buttonGrp
-- window that holds all components
local window = octane.gui.create
    type     = octane.gui.componentType.WINDOW,
    text     = "Turntable Animation",
    children = { panelStack },
    width    = panelStack:getProperties().width,
    height   = panelStack:getProperties().height,
window:showWindow()
Here are some screenshots:
If there are questions, please ask.
cheers,
Thomas
stratified
Re: Panel stack example script
Postby MB » Sat Mar 15, 2014 2:21 am
MB Sat Mar 15, 2014 2:21 am
I would like to avoid showing a bunch of empty space below the collapsed panel stack items.
I can't seem to figure it out. I'm guessing on the mouse event one should toggle the height of the main form, however if my panel stack is not the last item, that simply truncates those that are.
Coulds you please provide some sample code.
many thanks
Mark
MB
Postby stratified » Mon Mar 17, 2014 7:29 pm
stratified Mon Mar 17, 2014 7:29 pm
Hi Mark,
We don't support resizing yet in lua. That means if everything is collapsed you'll have empty space and then when everything is expanded you need to scroll. Not much we can do about it right now.
cheers,
Thomas
stratified
Return to Lua Scripting
Users browsing this forum: No registered users and 24 guests
Sat Apr 27, 2024 8:07 pm [ UTC ]
