Generating a Mandelbrot texture in Lua
Forums: Generating a Mandelbrot texture in Lua
Postby stratified » Mon Dec 30, 2013 8:13 am
stratified Mon Dec 30, 2013 8:13 am
Hi everybody,
Here's a example of how to create a procedural texture. It generates the Mandelbrot set in Lua. This script is just me goofing off, the script won't cure cancer or create world peace. For the one interested in Mandelbrot set, you can read all about them here:
http://en.wikipedia.org/wiki/Mandelbrot_set
All it does is colour the pixels that are in the Mandelbrot set orange and the others black:
-- @description Creates a Mandelbrot set texture node.
-- @author      Stratified
-- @version     0.1
-- The code to generate the Mandelbrot set is a modified version of this code:
-- http://www.timestretch.com/article/mandelbrot_fractal_benchmark#aba942b3e0f9e50dd67b83d89ec88139
local BAILOUT        = 4
local MAX_ITERATIONS = 1000
-- Checks if a pixel in the image plane is in the mandelbrot set.
-- Returns 0 if the pixel is not. The modulus of the last generated
-- complex number is returned when the thing is in the set
-- Boring theory:
-- A point c (complex number really) is in the Mandelbrot set if the series
-- generated by z(n+1) = z(n)^2 + c (with z(0) = 0 + j*0) is not going to infinity.
local function inMandelbrotSet(x, y)
   local cr = x
   local ci = y
   local zi = 0.0
   local zr = 0.0
   local k  = 0
   while 1 do
      k = k+1
        -- calculate z(n+1) from z(n)
      local zrzi2 = zr * zi * 2
      local zr2   = zr * zr
      local zi2   = zi * zi
      zr = zr2 - zi2 + cr
      zi = ci + zrzi2
        -- check if we're still bound, bail out if not
      if (zi2 + zr2 > 4) then
         return false
      end
        -- if we reached the maximum number of iterations and the last value
        -- of the generated series is still bounded, we assume the pixel is
        -- in the Mandelbrot set.
      if (k > MAX_ITERATIONS) then
            return true
      end
   end
end
-- Generates a Mandelbrot set centered around the centre of the image.
function genMandelbrotTex(w, h)
    -- create a data structure for the image
    local image  = {}
    image.size   = { w, h }
    image.type   = octane.image.type.LDR_RGBA
    image.buffer = {}
    -- see which pixels are in the Mandelbrot set
   for y = 0, h-1 do
      for x = 0, w-1 do
            -- transform x so it's in the range [-2, 1]
            local sx = 3 * (x / w) - 2
            -- transform y so it's in the range [-1, 1]
            local sy = 2 * (y / h) - 1
            local colour = inMandelbrotSet(sx, sy)
            -- colour pixels in the set
         if colour then
                table.insert(image.buffer, 255)
                table.insert(image.buffer, 127)
                table.insert(image.buffer, 0)
            -- pixels not in the set are black
         else
         end
      end
   end
    return image
end
-- dimensions of the generated texture
local WIDTH, HEIGHT = 400, 400
-- actually create the Mandelbrot texture
local tex = genMandelbrotTex(WIDTH, HEIGHT)
assert(#tex.buffer == 4 * WIDTH * HEIGHT, "invalid buffer length")
-- create an image texture node
texNode = octane.node.create{ type=octane.NT_TEX_IMAGE, name="Mandelbrot Texture" }
-- set up the gradient in the attributes
texNode:setAttribute(octane.A_BUFFER , tex.buffer , false)
texNode:setAttribute(octane.A_SIZE   , tex.size   , false)
texNode:setAttribute(octane.A_TYPE   , tex.type   , false)
-- evaluate the texture node
texNode:evaluate()
Here's the texture mapped on a cube:
Mandelbrot set mapped on a cube
The colours are still a bit lacking, a gradient would be nicer...
cheers,
Thomas
stratified
Re: Generating a Mandelbrot texture in Lua
Postby bepeg4d » Sat Jan 04, 2014 5:27 pm
bepeg4d Sat Jan 04, 2014 5:27 pm
thanks thomas, i really don't know how and when it will come in handy... but i'm having a big fun with your lua scripts :D
i have changed the fourth color to 255 for solid alpha and it works great ;)
ciao beppe
Postby stratified » Sat Jan 04, 2014 8:28 pm
stratified Sat Jan 04, 2014 8:28 pm
Hi Beppe,
Don't think this one is that useful, I just did it for the fun ;)
But fractals can be really beautiful:
http://www.smashingmagazine.com/2008/10/17/50-phenomenal-fractal-art-pictures/
cheers,
Thomas
stratified
Postby bepeg4d » Sun Jan 05, 2014 2:02 pm
bepeg4d Sun Jan 05, 2014 2:02 pm
thanks for the link, it was a lot of time without seeing some fractal images... cubik olympic is my prefered one ;)
ciao beppe
Postby Proupin » Sun Jan 05, 2014 6:00 pm
Proupin Sun Jan 05, 2014 6:00 pm
It would be cool if there were some sliders and stuff, and see the changes, but I don't know if that's possible...
Win 7 64bits / Intel i5 750 @ 2.67Ghz / Geforce GTX 470 / 8GB Ram / 3DS Max 2012 64bits
http://proupinworks.blogspot.com/
Proupin
Postby stratified » Sun Jan 05, 2014 7:12 pm
stratified Sun Jan 05, 2014 7:12 pm
sure, that's possible. You could do real time zooming in on the set. But I don't have the time to do that so if you're keen...
cheers,
Thomas
stratified
Return to Lua Scripting
Users browsing this forum: No registered users and 18 guests
Sat Apr 27, 2024 10:06 pm [ UTC ]
