Nodes and Nodegraphs in Lua.
Forums: Nodes and Nodegraphs in Lua.
Re: Nodes and Nodegraphs in Lua.
Postby stratified » Tue Jan 21, 2014 7:42 pm
stratified Tue Jan 21, 2014 7:42 pm
hi there,
octane.project.select adds an item to the current selection (the items with a yellow border in the nodegraph editor).
If you don't want to select nodes manually, you have to search for them in the scene's root graph (octane.nodegraph.getRootGraph()). You can search by name (octane.nodegraph.findItemsByName) or by type (octane.nodegraph.findNodes). In your case I guess it's the easiest to search by name:
nodes = octane.nodegraph.getRootGraph():findItemsByName("V6Torso")
cheers,
Thomas
stratified
Postby Slide3D » Wed Jan 22, 2014 12:38 am
Slide3D Wed Jan 22, 2014 12:38 am
stratified wrote:hi there,
cheers,
Thomas
does not work :(
local  v6mesh, mface = nil, nil
local selection = octane.project.getSelection()
if selection[1]:getProperties().type == octane.NT_GEO_MESH then
v6mesh = selection[1]
else
    error("a mesh need to be selected")
end
mface = octane.nodegraph.getRootGraph():findItemsByName("face")
v6mesh:connectTo("Face", mface)
i7 2600k, 16gb, Quadro FX1800(not use in Octane) + GTX580 1536Mb
Slide3D
Postby roeland » Wed Jan 22, 2014 1:48 am
roeland Wed Jan 22, 2014 1:48 am
The error message tells you the problem:
bad argument #2 to 'connectTo' (octane.node expected, got table)
findItemsByName gives you a list of nodes with this name, not a single node. You can check these things in the API browser (click the button with the question mark). So this second argument should be mface[1].
Roeland
roeland
Postby Slide3D » Wed Jan 22, 2014 1:56 am
Slide3D Wed Jan 22, 2014 1:56 am
roeland wrote:The error message tells you the problem:
Roeland
Thanks!!!
it's worked!
Slide3D
Previous
Return to Lua Scripting
Users browsing this forum: No registered users and 13 guests
Fri Apr 26, 2024 11:20 am [ UTC ]
