BG Random UV Projection node
Forums: BG Random UV Projection node
Postby bepeg4d » Sun Oct 21, 2018 9:57 pm
bepeg4d Sun Oct 21, 2018 9:57 pm
Hi all,
here is an OSL Projection node to randomise position, rotation and scale of the uvs of scattered objects. It uses the Random Color Texture node to obtain the random values, but you can use any other texture node:
https://vimeo.com/296310449
Hint #1:
Connect the same Random Color Texture node used to drive the OSL Projection, firstly into a Gradient node to batter control the range, and then in the Power pin of the ImageTexture node, to randomly change also the aspect of the texture over clones:
Here is the OSL script:
BGrandomUVproj_osl.zip
(931 Bytes) Downloaded 936 times
an .orbx example scene:
BGrandomUVproj_orbx.zip
(368.75 KiB) Downloaded 631 times
and a c4doctane example scene:
BGrandomUVproj_c4d.zip
(465 KiB) Downloaded 862 times
Hint #2:
If you use the following OSL Texture node RandomInstanceColor.osl, provided by Milanm here:
#include <octane-oslintrin.h>
shader RandomInstanceColor(
      int Seed=0,
      output color c = 0)
      c = noise("cell",_getinstanceid(),Seed);
Instead of a Random Color node, the BGRandomUVProjection OSL node works also with non instanced objects too.
In Standalone you need to have a Scatter object connected to each different object:
While in c4doctane you need to add an Octane Object tag, with differet Instance ID numbers, for example selecting all the tags, and entering num+1:
Here is a a Standalone .orbx, and .c4d example scene with both osl scripts working together:
randomuvsonobjects.zip
(2.32 MiB) Downloaded 787 times
Happy GPU Rendering,
ciao Beppe
Re: BG Random UV Projection node
Postby FxDesign » Thu Oct 25, 2018 4:04 pm
FxDesign Thu Oct 25, 2018 4:04 pm
That's fantastic, thank you
FxDesign
Postby funk » Wed Dec 05, 2018 3:45 am
funk Wed Dec 05, 2018 3:45 am
Thanks Beppe. Very handy!
Win10 Pro/ Ryzen 5950X / 128GB / RTX 4090 / MODO
funk
Postby J.C » Wed Dec 05, 2018 8:48 am
J.C Wed Dec 05, 2018 8:48 am
Wow!. Awesome script. Thanks for sharing Beppe!
System – Windows 11
J.C
Postby bepeg4d » Sun Mar 03, 2019 9:47 am
bepeg4d Sun Mar 03, 2019 9:47 am
I have updated the first post with the great hint provided by Milanm here, of using the OSL Texture node RandomInstanceColor.osl, instead of the Octane Random Color node.
ciao Beppe
Postby pxlntwrk » Sun Mar 03, 2019 5:30 pm
pxlntwrk Sun Mar 03, 2019 5:30 pm
thanks bepeg,
that's really cool and useful...
pxlntwrk.net
pxlntwrk
Postby neilmanisharma » Fri Feb 07, 2020 10:25 am
neilmanisharma Fri Feb 07, 2020 10:25 am
Can you tell me how it will work in blender? As i tried using OSL texture but it is giving error.
neilmanisharma
Postby roy_orengo » Sat Apr 04, 2020 9:15 am
roy_orengo Sat Apr 04, 2020 9:15 am
Hi Beppe,
You wrote:
"Instead of a Random Color node, the BGRandomUVProjection OSL node works also with non instanced objects too".
So I could use It without Blocks (I'm using Rhinoceros as modeller)? On different solids?
ciao,
Roy
roy_orengo
Postby mortom_ckm » Sat Dec 12, 2020 9:07 pm
mortom_ckm Sat Dec 12, 2020 9:07 pm
Hi I'm green in this stuff - In Octane I mean :)
There is a way to do this in Octane for Blender? I suppose connect node "OSL Projection" with script to the shader it's not do the trick?
mortom_ckm
Postby mortom_ckm » Sun Dec 13, 2020 11:41 am
mortom_ckm Sun Dec 13, 2020 11:41 am
Hi
There is a way to do this in Blender?
mortom_ckm
Next
Return to Lua Scripting
Users browsing this forum: No registered users and 22 guests
Sat Apr 27, 2024 4:12 am [ UTC ]
