Multiple VM on a same AMI
Forums: Multiple VM on a same AMI
Discussion forum for ORBX on OTOY's Amazon AMIs
Postby jojo » Fri Feb 28, 2014 5:53 am
jojo Fri Feb 28, 2014 5:53 am
Can we have more than 1 VM on the same AMI ?
With each VM running different application
jojo
Re: Multiple VM on a same AMI
Postby Goldorak » Fri Feb 28, 2014 6:57 am
Goldorak Fri Feb 28, 2014 6:57 am
You might be able to do this with something like virtualbox - but then you lose high end GPU support in the VM. If you don't need GPU support, it might be easier to use a smaller CPU instance for each host, rather than trying to split a larger instance into multiple ones. Behind the scenes, AWS is basically doing this for you - the smaller instances are basically Xen VMs that are partitioned form the larger instance types.
Goldorak
Return to ORBX on Amazon AMIs
Who is online
Users browsing this forum: No registered users and 2 guests
Thu May 09, 2024 12:33 pm [ UTC ]
