OctaneRender 2021 for Revit [OBSOLETE]
Forums: OctaneRender 2021 for Revit [OBSOLETE]
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Postby face_off » Mon Nov 22, 2021 11:24 am
face_off Mon Nov 22, 2021 11:24 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Revit - TEST and STABLE releases.
Revit Version
This version runs on Revit 2021 and 2022 on Windows Vista, Windows 7, Windows 8 and Windows 10, 64 bit.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Revit version and build number (Help -> About Revit -> Build Number)
- OctaneRender for Revit version (ie. 1.02a)
- If relevant - supply the Journal file for the Revit session where the support issue occurred. Journal files can be found in C:\Users\[username]\AppData\Local\Autodesk\Revit\Autodesk Revit [Revit version]\Journals
For more information
- Check the specific Octane 2.0 features in this plugin at http://render.otoy.com/manuals/Revit/?page_id=536
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Download Links
Current STABLE build (Octane 2020.1.4)
Previous STABLE build (Octane 2020.1)
Release History
2021.1.4.68 (5-Apr-2022)
- Compiled with Octane 2021.1.4
- Resolved error where the OctaneRender AddIn could not be opened more than once in a Revit session
- Fixed a number of color mapping issues introduced in 2021.1.0.67 related to the Octane OCIO implementation (not implemented in this plugin)
2021.1.0.67 (22-Nov-2021)
- The following features from https://render.otoy.com/forum/viewtopic.php?f=33&t=77764 are now supported by the plugin:
... Improved RTX support
... Interpolated surface tangents
... Clipping material
... Energy preserving GGX BRDF
... Improved hair material
... Improved AI light
... New texture nodes
... New projection nodes
- The following features from viewtopic.php?f=33&t=77764 are NOT supported by the plugin (however most are supported if you import an ORBX proxies with the feature):
... SDF from mesh
... Improved Scatter on surface
... Volume rendering
... Improved color processing
... Refactored render AOVs
... Custom AOVs
... Global texture AOVs
... New output AOVs
Re: OctaneRender 2021 for Revit [TEST and STABLE]
Postby face_off » Tue Apr 05, 2022 5:36 am
face_off Tue Apr 05, 2022 5:36 am
I have updated the installers at the top of this thread with:
2021.1.4.68
Return to Autodesk Revit
Users browsing this forum: No registered users and 29 guests
Fri Apr 26, 2024 6:13 am [ UTC ]
