walk through
Forums: walk through
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
walk through
Postby jimho » Wed May 12, 2021 12:56 pm
jimho Wed May 12, 2021 12:56 pm
Hello,
does anyone know if walk through is still supported?
I tried a simple minimum scene but it seems not working, I tried the latest two version 65,66 both are the same on revit 2019, revit 2021...
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
jimho
Re: walk through
Postby face_off » Thu May 13, 2021 12:15 am
face_off Thu May 13, 2021 12:15 am
Hi - are you using the English version of Revit?
Re: walk through
Postby jimho » Thu May 13, 2021 4:49 pm
jimho Thu May 13, 2021 4:49 pm
Yes they are.
jimho
Re: walk through
Postby face_off » Fri May 14, 2021 5:03 am
face_off Fri May 14, 2021 5:03 am
Thanks. Can you please supply the Journal file for the Revit session where a walkthru animation has failed. Journal files can be found in C:\Users\[username]\AppData\Local\Autodesk\Revit\Autodesk Revit [Revit version]\Journals.
Re: walk through
Postby jimho » Fri May 14, 2021 12:46 pm
jimho Fri May 14, 2021 12:46 pm
Thanks,here are the journals, hope they may help:
Journals.rar
(34.13 KiB) Downloaded 266 times
jimho
Re: walk through
Postby face_off » Mon May 17, 2021 4:05 am
face_off Mon May 17, 2021 4:05 am
Hi. I cannot see anything wrong in the journal file. Are you able to send me the simple walk-thru .rvt file you are using please?
Re: walk through
Postby jimho » Mon May 17, 2021 6:12 am
jimho Mon May 17, 2021 6:12 am
it just means from my side any walk through will not be exported, it is nothing to do with the specific file...
walkthrough.rar
(4.39 MiB) Downloaded 284 times
jimho
Re: walk through
Postby face_off » Wed May 19, 2021 4:31 am
face_off Wed May 19, 2021 4:31 am
I have looked into this issue in detail, and it appears that all the UI automation tools that the plugin uses to interact with the Revit UI (ie. the method used to click the "Next Frame" button) are no longer working in Revit 2019 and Revit 2020. I will see if there is another way of implementing this, however it might be a case that the walk-thru's can no longer be rendered.
Re: walk through
Postby jimho » Wed May 19, 2021 4:38 pm
jimho Wed May 19, 2021 4:38 pm
Thanks Paul.
It's good to know, revit 2018 can still do walk through with octane
jimho
Re: walk through
Postby face_off » Wed May 19, 2021 10:47 pm
face_off Wed May 19, 2021 10:47 pm
I am unsure of which Revit version the UI automation process changed. So you would need to test it on Revit 2018 yourself to find out (or I will test it when doing the next release).
Next
Return to Autodesk Revit
Fri Apr 26, 2024 8:26 pm [ UTC ]
