How to export revit to standalone?
Forums: How to export revit to standalone?
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Re: How to export revit to standalone?
Postby SamuelAB » Fri Jul 21, 2017 2:28 am
SamuelAB Fri Jul 21, 2017 2:28 am
Amazing, thank you!
SamuelAB
Postby prehabitat » Sat Aug 05, 2017 4:03 am
prehabitat Sat Aug 05, 2017 4:03 am
P.s. You can orient an orthogonal camera view to a plane or a view (like a floor plan view for example) without needing to create a section first by using the drop menu in the camera steering wheel controls. (Turn on via Shift+w from within any 3D view)
Look for 'orient to view' 'orient of plane' (or google it to get the autodesk instructions).
dependinf on how 'long' you drew the camera you can just adjust Far Clip Offset parameter to capture more or less depth from camera.
Also, using this method you can do a perfectly centred, perspective plan view which can be quite striking ...
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
prehabitat
Previous
Return to Autodesk Revit
Fri Apr 26, 2024 6:10 pm [ UTC ]
