OctaneRender 2022 for Revit [OBSOLETE]
Forums: OctaneRender 2022 for Revit [OBSOLETE]
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Postby face_off » Fri Aug 19, 2022 7:28 am
face_off Fri Aug 19, 2022 7:28 am
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Revit - TEST and STABLE releases.
Revit Version
This version runs on Revit 2022, 2023 and 2024 on Windows Windows 7, 8, 10 and 11, 64 bit.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Revit version and build number (Help -> About Revit -> Build Number)
- OctaneRender for Revit version (ie. 1.02a)
- If relevant - supply the Journal file for the Revit session where the support issue occurred. Journal files can be found in C:\Users\[username]\AppData\Local\Autodesk\Revit\Autodesk Revit [Revit version]\Journals
For more information
- Check the specific Octane 2.0 features in this plugin at http://render.otoy.com/manuals/Revit/?page_id=536
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Download Links
Current STABLE build (Octane 2022.1.1)
Previous TEST build (Octane 2022.1 XB3)
Release History
2022.1.1.71 (28-Jul-2023)
- Compiled with Octane 2022.1.1
- Added support for Revit 2024 and removed support for Revit 2021
2022.1.0.70 (14-Dec-2022)
- Added new texture nodes from Octane 2022.1 XB4
- IMPORTANT: Octane 2022.1 changes the way the Daylight Environment renders, and changes the way volumes render, so old scene using either of these Octane features may render differently
- Added support for Revit 2023
2022.1.0.69 (19-Aug-2022)
- Compiled with Octane 2022.1 XB3
- Added the Standard Surface Material node
- Implemented the Octane 2022.1 change "Image nodes now have a Border mode for U and V separately."
- Added Textures->Fields nodes
- Added C4D noise nodes
- Added Values->Utility nodes
- Added the Photon Tracing Kernel
- Removed the Imager->Pre-Multipled Alpha pin, as this is no longer used with Octane 2022.1.
- Added new Texture nodes from Octane 2022.1 XB2
- Added the Curvature Visibility property from Octane 2022.1 XB3
Re: OctaneRender 2022 for Revit [TEST and STABLE]
Postby face_off » Wed Dec 14, 2022 1:08 am
face_off Wed Dec 14, 2022 1:08 am
I have updated the installers at the top of this thread with:
2022.1.0.70
Postby face_off » Fri Jul 28, 2023 2:07 am
face_off Fri Jul 28, 2023 2:07 am
2022.1.1.71
Return to Autodesk Revit
Users browsing this forum: No registered users and 13 guests
Fri Apr 26, 2024 4:26 am [ UTC ]
