Proxy selection
Forums: Proxy selection
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Proxy selection
Postby Jasonr » Sat Feb 04, 2017 1:12 pm
Jasonr Sat Feb 04, 2017 1:12 pm
Is it possible to be able to have lamps for proxy selection and not just objects?
This would have been really useful and time saving as lamps are a different category inside archicad (because of their lighting attributes)
You can save a lamp as an object and use it but in order to cancel that step it is necessary for Octane to be able to use lamps as proxy right away.
I have no idea if this is difficult to implement but it is a suggestion.
Thank you so much.
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
Jasonr
Re: Proxy selection
Postby face_off » Sun Feb 05, 2017 11:03 am
face_off Sun Feb 05, 2017 11:03 am
I'm not sure if this would be possible or not. The proxy system relies on a number of parameters obtained from the ArchiCAD API specifically for Object items, and I doubt these would be available for lamps. But I will take a closer look when doing the next release.
Re: Proxy selection
Postby Jasonr » Sun Feb 05, 2017 6:52 pm
Jasonr Sun Feb 05, 2017 6:52 pm
Thank you Paul for yoy direct support.
Jasonr
Return to Graphisoft ArchiCAD
Mon May 06, 2024 8:57 am [ UTC ]
