OctaneRender 2020 for ArchiCAD [OBSOLETE]
Forums: OctaneRender 2020 for ArchiCAD [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Re: OctaneRender 2020 for ArchiCAD [TEST and STABLE]
Postby Jasonr » Fri Mar 12, 2021 2:16 pm
Jasonr Fri Mar 12, 2021 2:16 pm
Hi Paul.
I am using some ies lights and trying to find a node called efficiency at the emmision channel.
Seems it is not available or I am doing something wrong.
I do not know if it can be implemented if it is not already there but seems usefull as we can adjust the power of the light
to make more realistic the lighting result.
I am not sure whether efficiency is the texture node with a greyscale colour (0-1).....propably not because if I set the correct value it does not work correctly.
Any help would be appreciated.
Warm regards to everybody.
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
Jasonr
Postby face_off » Mon Mar 15, 2021 11:53 pm
face_off Mon Mar 15, 2021 11:53 pm
Hi
The "Efficiency or texture" pin was renamed "Texture" some time back - so use it (and the Power) to control the intensity.
Postby face_off » Tue Jul 06, 2021 11:13 pm
face_off Tue Jul 06, 2021 11:13 pm
I have posted a test version of the plugin for Octane 2021.1 at https://render.otoy.com/forum/viewtopic.php?f=56&t=78052. I am not planning on doing any more releases for Octane 2020.
Re: OctaneRender 2020 for ArchiCAD [OBSOLETE]
Postby face_off » Mon Nov 08, 2021 12:47 am
face_off Mon Nov 08, 2021 12:47 am
This version of the plugin is now obsolete, and replaced with https://render.otoy.com/forum/viewtopic.php?f=56&t=78052.
Previous
Return to Graphisoft ArchiCAD
Tue Jun 04, 2024 7:17 am [ UTC ]
