Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Postby Jedi_blade » Mon Jul 20, 2020 6:30 pm
Jedi_blade Mon Jul 20, 2020 6:30 pm
I just bought a Mac Pro (2019) last month. If I buy a sub for now until Big Sur comes out, will I lose my free license then?
I asked this a minute ago, but OTOY got back to me and said no, it does not hurt the free license. I am ready to play.
Jedi_blade
Postby imcalledandy » Mon Jul 20, 2020 6:33 pm
imcalledandy Mon Jul 20, 2020 6:33 pm
natemac00 wrote:With an external GPU using an AMD card, that should work?
Yes. Get a Radeon VII or 5700XT and you’re all set.
imcalledandy
Postby ttttb » Mon Jul 20, 2020 6:39 pm
ttttb Mon Jul 20, 2020 6:39 pm
plasmapeppers wrote:Wow! How much more exciting can it get - but when I try to use the PR1 Standalone demo it keeps failing. Octane's Log says
Compute error 2097152:113:
compute device 0: Linking 6d197dfc90d19e72 shader failed
device 0: failed to initialize render thread 0x7fa15c77ce50
Not sure what's wrong here - its just a default cube. I am running a 2018 Mac mini i7 32GB with a Radeon VII eGPU - on macOS 11 Big Sur Beta 2(maybe thats what is wrong?)
Same error on MacBook Pro (16-inch), AMD Radeon Pro 5500M 4 GB, Catalina 10.15.6 (19G73), C4D R20.059
ttttb
Postby atoyuser1 » Mon Jul 20, 2020 6:43 pm
atoyuser1 Mon Jul 20, 2020 6:43 pm
Yes - updated the FAQ to note that only 10.15.6 is supported!
I'm also getting the same error. Running 10.15.6 (19G73):
Octane X Studio PR1 (10000024)
device 0: failed to initialize render thread 0x7f8aed70fc40
atoyuser1
Postby Goldorak » Mon Jul 20, 2020 6:50 pm
Goldorak Mon Jul 20, 2020 6:50 pm
Make sure to use C4D R21 for Octane X:
Note - the Octane X plug-in for C4D should be run on R21. Ahmet noted instability in R20 and R22, so that's the version to test. Same with Maya 2020 and SketchUp 2020, those are the versions to to use with Octane X.
I will add this to the FAQ.
Goldorak
Postby kirilyukvv » Mon Jul 20, 2020 6:51 pm
kirilyukvv Mon Jul 20, 2020 6:51 pm
How can I install demo C4D plugin Octane X?
kirilyukvv
Postby Dmikucki » Mon Jul 20, 2020 7:16 pm
Dmikucki Mon Jul 20, 2020 7:16 pm
Waiting on support to get my Blender download working, but during my lunch break I threw a high-resolution OBJ onto an HDRI environment and things seem to render pretty fast on a 5600M. Super simple scene, though. Single OBJ with diffuse shaders/textures with a 4k HDR set to path tracing. But the viewport is beautifully responsive. Hoping this scales up well for larger projects.
Dmikucki
Postby eduorell » Mon Jul 20, 2020 7:18 pm
eduorell Mon Jul 20, 2020 7:18 pm
Guys I have 2 questions: How does this work with a macbook 16 i7 with a AMD Radeon Pro 5300M? My other option is a egpu with a RX 5700 XT.
Also, could you render combining these two cards? Thanks.
eduorell
Postby design monkey » Mon Jul 20, 2020 7:35 pm
design monkey Mon Jul 20, 2020 7:35 pm
compute device 1: Linking 6d197dfc90d19e72 shader failed
device 0: failed to initialize render thread 0x7fe79244d3d0
device 1: failed to initialize render thread 0x7fe79244dbf0
I'm getting the same errors as some others running on a Mac Mini, 10.15.6, (2x) RX5700XT eGPU's & C4D R20. So what's the solution if we just paid for Octane X only to find out there's only one version of C4D that it's compatible with, and no one bothered to tell us this kind of important information? A tad bit frustrating.
design monkey
Postby atoyuser1 » Mon Jul 20, 2020 7:48 pm
atoyuser1 Mon Jul 20, 2020 7:48 pm
Goldorak wrote:Make sure to use C4D R21 for Octane X:
Tried it in R21 and it works! Thanks
One thing I noticed is that vertex maps aren't displaying, but I haven't had a proper play around with it yet
atoyuser1
PreviousNext
Return to Graphisoft ArchiCAD
Thu Jun 06, 2024 12:46 pm [ UTC ]
