Export BatchRender Plugin (publishing set) to Standalone
Forums: Export BatchRender Plugin (publishing set) to Standalone
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Postby rappet » Sat Oct 21, 2017 11:19 am
rappet Sat Oct 21, 2017 11:19 am
Hi Guys, especially Paul ;) ,
I was wondering if you ArchiCAD users use the Batchrendering?
Do you use it a lot, how do you use it.. and maybe you can share your experience and wishes here.
I am using the ArchiCAD BatchRendering quit a lot using the AC Publisher Set,
having the same target name for all cameras...
It works fine.
Example of how you see here: download/file.php?id=21315&mode=view)
But now I was wondering if I could export it to the OctaneRender standalone.. when exporting the scene to orbx/ocs I only have one camera exported, right?
So might there be a way to exsport from plugin/ArchiCAD to the standlone with multiple cameras and have a simple to use BatchRender in the standlone as well?
The best thing would be exporting the AC publish set to an orbx file and a BatchRender file as well for all the cameras to use in the Standalone by importing it using Lua Scripting.
@Paul, do you see any possibility here? Maybe for the plugin.. or for someone else to write something for the Lua Scripting.. or otherwise?
greetz,
rappet
Re: Export BatchRender Plugin (publishing set) to Standalone
Postby face_off » Sun Oct 22, 2017 12:02 pm
face_off Sun Oct 22, 2017 12:02 pm
It would probably be possible to export each of the cameras from each of the Publishing Sets. But this would be quiet a lot of work to implement - so only something worth doing if it was going to be used by a significant number of users.
Postby rappet » Sun Oct 22, 2017 12:16 pm
rappet Sun Oct 22, 2017 12:16 pm
face_off wrote:It would probably be possible to export each of the cameras from each of the Publishing Sets. But this would be quiet a lot of work to implement - so only something worth doing if it was going to be used by a significant number of users.
It is not going to be used by a significant number of users, so I need to find another solution..
I might have an idea, but that is outside plugin, and probably something for Lua Scripting
When exporting it to an orbx I have one camera...let us say with position 0,0 (for x,y)..
then having cameras for the Batch in a sequence..ie. with distance 50 meters
i.e. x,y with 0,50.000/0,100.0000/ 0,150.000/ and so on...
then a Lua Script would be possible I guess... I need to drop this question in the other general forum about Lua Scripting.
greetz,
rappet
Postby Jasonr » Sun Oct 22, 2017 2:45 pm
Jasonr Sun Oct 22, 2017 2:45 pm
Hi to all.
In the past I was batch-rendering a lot with Artlantis.
Never used rendering with Archicad.
So unfortunately i cannot help.
Indeed when we export a scene as orbx only one camera position is availalble.
It will be usefull to be able to save several camera positions and have only one orbx file exported.
I do not know exaclty how to batch render with octane but if this function gets availabla for sure I will use it.
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
Jasonr
Postby rappet » Mon Oct 23, 2017 10:46 am
rappet Mon Oct 23, 2017 10:46 am
Hi Jason,
Why did you never render a batch of visuals in Archicad with Octanerender plugin as the render engine?
Because you did not need to or do not know how?
I would not be able to do my projects without this functionality!
I am doing a lot of housing projects with options that need to visualised.
I could render lots of jpgs with just one click.
I did not mange to find a way to render png files with transparant backgrounds though...
Gotta try to figure that out if possible.
Cheers,
rappet
Postby Jasonr » Mon Oct 23, 2017 11:13 am
Jasonr Mon Oct 23, 2017 11:13 am
Hi Rappet.
Hope you are well.
When we started using Octane one year ago we started making only 360 pictures through Octane.
The customers come to the office and get a real-time presentation which is less time consuming than preparing several photos.
We spent more time for constructural design than presentation.
Regards.
Jasonr
Return to Graphisoft ArchiCAD
Users browsing this forum: No registered users and 17 guests
Fri Apr 26, 2024 3:02 pm [ UTC ]
