Thanks guys for your interest and help in my spare time work!
The Aston Martin is not my work. I bought it on Turbosquid... I'm absolutely not on that level in modeling
Trees and bushes are from Plant Factory (also bought things). Every other model was made by me.
I mentioned that there is a photo which I use as a reference. Here it is:
- 1390324939-mg-a3srgb.jpg (65.32 KiB) Viewed 3757 times
As you can see, they used the same, very distorted view angle.
I don't want to reproduce this very strong contrast you can see, but I wanted to focus on the roof, which is the real topic of this render.
I'm now working on an other setup. I changed to HDRI environment, chose a slightly longer lens, fixed the above mentioned problems (or at least tried to), like the shader of the car, the details in the shady sides, and the slabs under the car.
All the changes together requires more video memory than my 970's have, so I can use only my two 1070, and the HDRI environment slows down the rendering speed very-very much, so stay tuned, I will update this post again if I have an acceptable render again.
Until then, thanks again!
