Animation: Refreshing geometry once instead of every frame
Forums: Animation: Refreshing geometry once instead of every frame
Postby Petec » Thu Feb 20, 2020 4:59 am
Petec Thu Feb 20, 2020 4:59 am
For animating with Octane where the meshes move (i.e. refresh geometry is required), I am curious as to whether there is a way to do all that on the front end or do it faster, rather than resend all the meshes (whether or not they move) from Poser to Octane with every frame change. If I recall correctly the Daz plugin seems to move between frames quite quickly, or at least compared to the Poser plugin.
In short, I would love to find a way to cut down on the wait time when refreshing geometry for animations.
Petec
Re: Animation: Refreshing geometry once instead of every frame
Postby face_off » Thu Feb 20, 2020 8:17 am
face_off Thu Feb 20, 2020 8:17 am
I think you are looking for a Camera-only animation? This is not currently possible with the plugin - sorry. You can however export the animation to an ORBX file and render it in Octane Standalone, which may satisfy part of your need.
Postby Petec » Sat Feb 22, 2020 1:35 am
Petec Sat Feb 22, 2020 1:35 am
Thanks Paul.
As someone with Studio subscription, do I even have access to the standalone version anymore? Also, will I have to redo materials and lighting and such with an orbx file export or does that all get carried over into standalone?
face_off wrote:I think you are looking for a Camera-only animation? This is not currently possible with the plugin - sorry. You can however export the animation to an ORBX file and render it in Octane Standalone, which may satisfy part of your need.
Petec
Postby wimvdb » Sun Feb 23, 2020 10:16 pm
wimvdb Sun Feb 23, 2020 10:16 pm
Orbx keeps all material settings, I use it often when I want to have motion blur. I use the option to embed the textures in the orbx to avoid potential file reference failures.
With a Poser plugin you need a license for both the Poser plugin and for the standalone. In that case you can download the stand alone. I have no idea if it is the same with the studio subscription (but i suspect the same)
Petec wrote:Thanks Paul.
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
wimvdb
Postby face_off » Mon Feb 24, 2020 11:14 pm
face_off Mon Feb 24, 2020 11:14 pm
Yes, just install the Octane Standalone STUDIO version.
Postby Petec » Wed Mar 04, 2020 8:06 am
Petec Wed Mar 04, 2020 8:06 am
Thank you both, I appreciate it.
Petec
Return to Poser
Users browsing this forum: No registered users and 31 guests
Sat Apr 27, 2024 12:59 pm [ UTC ]
