Help with plants
Forums: Help with plants
Help with plants
Postby bpzen » Sun Jan 26, 2014 3:42 pm
bpzen Sun Jan 26, 2014 3:42 pm
Hi all, I have treid to figure out why in poser this plant/ivy looks fine and in 3DSMAX it looks fine, but when I load in Octane it seems to not covert at all, the image is here, it basicly showing the ivy plant as an image , i tried to take another plant that looks pretty good in octane save the poe, then import retaining images maps, but hat looks even worse,
anyon ehave ideas on how to get this to lookright ?
http://erotic3dx.com/misc/ivy.jpg
thanks
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
bpzen
Re: Help with plants
Postby Erick » Sun Jan 26, 2014 4:38 pm
Erick Sun Jan 26, 2014 4:38 pm
Almost looks like the opacity map(s) is (are) missing or got converted into the wrong place/pin, in the Octane material tree.
Or the leaves are not really "geometry", rather than a flat plane, or something.
Erick
Postby bpzen » Sun Jan 26, 2014 5:13 pm
bpzen Sun Jan 26, 2014 5:13 pm
Hi Erik, you were right.
The Alph / transparence maps were MIA? Fixed loadign it manualy, thanks !
bpzen
Postby face_off » Sun Jan 26, 2014 9:11 pm
face_off Sun Jan 26, 2014 9:11 pm
Yes - the transmap didn't get converted in the material. It would be worth checking if that plant rendered OK in Poser - if so, then the plugin has an issue. If not, then the export from 3ds did not work correctly.
Postby bpzen » Sun Jan 26, 2014 11:42 pm
bpzen Sun Jan 26, 2014 11:42 pm
Hi Paul, plug in is fine, I thought poser had them as they were there, then Psoer lost them not sure how. thanks for response
bpzen
Postby Zay » Mon Jan 27, 2014 1:08 pm
Zay Mon Jan 27, 2014 1:08 pm
Usually it's Poser to blame when import/export stuff to Poser. Many times when I export a scene from Poser to OBJ with textures and import it again to get a solid prop, Poser doesn't hook up the correct textures it has exported in the first place. So you have to manually add them in the material room. A big pain in the butt and also a bug if you ask me. Reported it over a year ago but still no fix for that.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 546.01| Modo/Blender/ZBrush/Daz/Poser
Zay
Return to Poser
Users browsing this forum: No registered users and 22 guests
Sat Apr 27, 2024 2:29 am [ UTC ]
