Paul,
...and anybody, if I've missed an obvious and existing method of accomplishing this I apologize and please tell me how...
let's say I have an article of clothing that has many material zones to it (Alfaseed is famous for this). When brought into the plugin, the specular is set to 1 making it render white-ish. Currently I go thru and reduce each value to 0 to bring out the full texture, and adjust from there any specular I need. For me it's easier to start from 0 and adjust up a few, than to first bring everything down from 1.
Same goes for globally modifying default bump values. I usually ramp everything up to 1 from what I can tell is a default .05.
The request: Can something be done in the plugin for globally changing values?
What made me think of this, alot of poser textures have this light blue color in the diffuse channel thats great for firefly but I don't like it in Octane. From the plug-in, I went thru each material and set the color to white. Very time consuming. I did this only once, before I remembered Snarlygribbly's SceneFixer and now use it to globally change the diffuse to white in one step before sending it to the plugin
Sam
