Low Video Card Memory Error
Forums: Low Video Card Memory Error
Postby morphious2013 » Fri Jun 28, 2013 11:41 pm
morphious2013 Fri Jun 28, 2013 11:41 pm
It doesn't happen if I load the Select the octane plugin under render tab. It happens when I open view port to render. At top of view flashing in RED is this error message."Warning! Low Video Card Memory. Sometimes it goes away, and renders, but really slow for the card I have. Doesn't happen all the time. Can a prop or texture cause this. I did not the scene contains 110 meshes during the octane plugin initialization process. I don't get a warning that I have exceeded my cards capabilities, and at the bottom it only shows using 898gb/2048gb, so it seems to have enough ram to render the scene. Any ideas? Thanks.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
morphious2013
Re: Low Video Card Memory Error
Postby face_off » Sat Jun 29, 2013 7:25 am
face_off Sat Jun 29, 2013 7:25 am
The low memory warning happen before the first sample is rendered, so if things are running slow you will see it for a few secs. This is fixed in the next version.
You can check the memory stats with the Image File Statistics button, or start rendering and mouseover the lower stats bar on the Viewport. What are they reporting? 110 meshes is an incredibly large number of meshes!
Postby morphious2013 » Sat Jun 29, 2013 3:23 pm
morphious2013 Sat Jun 29, 2013 3:23 pm
When is the next version due?
morphious2013
Postby face_off » Sat Jun 29, 2013 11:31 pm
face_off Sat Jun 29, 2013 11:31 pm
It will be release a day after I get version 1.20 of Octane. So maybe this week?
Postby morphious2013 » Thu Jul 04, 2013 7:31 pm
morphious2013 Thu Jul 04, 2013 7:31 pm
Were you able to fix this issue and when will new plugin be ready? Thanks.
morphious2013
Postby face_off » Thu Jul 04, 2013 10:32 pm
face_off Thu Jul 04, 2013 10:32 pm
The new version should be ready today. It contains a fix to the cosmetic issue of reporting low memory prior to sample 1, and it may contain a fix to the reporting of the number of vertices which using HDRI/sunlight lighting (I haven't been able to check yet).
Postby face_off » Sat Jul 06, 2013 12:54 am
face_off Sat Jul 06, 2013 12:54 am
Just letting you know that there has been a delay getting the 1.20 release out due to a technical issue. It will need to wait for Otoy's input early next week.
Postby morphious2013 » Sat Jul 06, 2013 3:31 pm
morphious2013 Sat Jul 06, 2013 3:31 pm
OK, thanks.
morphious2013
Return to Poser
Users browsing this forum: No registered users and 35 guests
Sat Apr 27, 2024 9:34 pm [ UTC ]
