Material Scale ?
Posted: Fri May 10, 2013 7:40 pm
by bpzen
Hello
I am trying to figure out how i can use a material in the Live DB but scale the texture down so it fits the scene. Example, I am using a floor tile, when i load the material on the poser prop the tile look HUGE, iv messed with all the setting that seem to indicate they would adjust scale - but cant figure out if or what dial would do the trick to reduce the visual size of the tile.
thanks
Re: Material Scale ?
Posted: Fri May 10, 2013 7:54 pm
by KleanZlate
Adjust the scale value under the image nodes. Note that higher values mean smaller images. You might have to adjust several images (diffuse, bump etc.)
Posted: Fri May 10, 2013 7:59 pm
by bpzen
perfect thank you
