Material Scale ?
Forums: Material Scale ?
Material Scale ?
Postby bpzen » Fri May 10, 2013 7:40 pm
bpzen Fri May 10, 2013 7:40 pm
Hello
I am trying to figure out how i can use a material in the Live DB but scale the texture down so it fits the scene. Example, I am using a floor tile, when i load the material on the poser prop the tile look HUGE, iv messed with all the setting that seem to indicate they would adjust scale - but cant figure out if or what dial would do the trick to reduce the visual size of the tile.
thanks
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
bpzen
Re: Material Scale ?
Postby KleanZlate » Fri May 10, 2013 7:54 pm
KleanZlate Fri May 10, 2013 7:54 pm
Adjust the scale value under the image nodes. Note that higher values mean smaller images. You might have to adjust several images (diffuse, bump etc.)
Windows 8 64bit, Intel Xeon 3.4 GHz x2, 10GB RAM, GTX 660 Ti 2GB, Poser Pro 2012 SR 3.1
KleanZlate
Postby bpzen » Fri May 10, 2013 7:59 pm
bpzen Fri May 10, 2013 7:59 pm
perfect thank you
bpzen
Return to Poser
Thu May 23, 2024 10:25 am [ UTC ]
