OctaneRender for DAZ Studio 2021.1.6 - 83 [OBSOLETE]
Forums: OctaneRender for DAZ Studio 2021.1.6 - 83 [OBSOLETE]
Moderator: BK
Re: OctaneRender for DAZ Studio 2021.1.6 - 83 [Test]
Postby RGUS » Mon Nov 14, 2022 1:08 am
RGUS Mon Nov 14, 2022 1:08 am
toby_a wrote:
RGUS wrote:When importing "Render Settings" from a previously saved file, the dimensions of the Octane Viewport are not saved or loaded back in and always default to initial dimensions.
I have to manually key in the dimensions each time. I'm sure it never use to do this or am I missing something?
Thanks for the report. Can you please clarify what you mean by "importing ... from a previously saved file"? Are you using the Import/Export buttons on the plugin's Rendersettings tab? Or are you merging a Daz scene using the File->Merge menu? Or something else?
Cheers,
Toby.
Oh, sorry... I mean I'm using the import button on the plugin render settings tab.
I render at predefined sizes and whenever I import one of the save settings, the dimensions revert to 720x480
RAM: 64GB
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
RGUS
Postby toby_a » Mon Nov 14, 2022 1:18 am
toby_a Mon Nov 14, 2022 1:18 am
RGUS wrote:Oh, sorry... I mean I'm using the import button on the plugin render settings tab.
Thanks, I'll take a look. I made some changes to the import/export functionality recently so I probably forgot to test this bit.
Cheers,
Toby.
toby_a
Postby Witpapier » Wed Nov 23, 2022 12:53 pm
Witpapier Wed Nov 23, 2022 12:53 pm
Hi there, Its been some time since Ive worked with Octane, but for some reason it is not detecting my 3090.
RedSpec TGX for Poser / OctaneRender - OUT NOW visit http://redspec-sss.com/
Witpapier
Postby toby_a » Wed Nov 23, 2022 7:56 pm
toby_a Wed Nov 23, 2022 7:56 pm
Witpapier wrote:Hi there, Its been some time since Ive worked with Octane, but for some reason it is not detecting my 3090.
Have you checked in Octane Standalone? What does the dialog show if you click on "Open Device Settings" on the System tab in the plugin?
toby_a
Postby delguy » Thu Nov 24, 2022 6:55 pm
delguy Thu Nov 24, 2022 6:55 pm
Hi ,
When can we expect the solution to issues raised with respec to this test version and can expect a stable version. Also we are almost at end of 2022. Any timeline for moving this to 2022 platform.
delguy
Postby toby_a » Thu Nov 24, 2022 8:51 pm
toby_a Thu Nov 24, 2022 8:51 pm
delguy wrote:Hi ,
Hi. I'm planning to release a new 2021.1.6-based version with some bug fixes either at the end of this week or early next week. This version will be marked STABLE and no new features will be added (bugfixes will be considered).
There have been some private test builds based on pre-release Octane 2022.1. I'm planning to release a public TEST version of the plugin based on the just-released Octane 2022.1 in the same time-frame.
Cheers,
Toby.
toby_a
Re: OctaneRender for DAZ Studio 2021.1.6 - 83 [OBSOLETE]
Postby toby_a » Fri Nov 25, 2022 2:00 am
toby_a Fri Nov 25, 2022 2:00 am
A new STABLE version based on 2021.1.6 is now available: viewtopic.php?f=44&t=80822
toby_a
Previous
Return to DAZ Studio
Users browsing this forum: No registered users and 7 guests
Mon May 13, 2024 9:32 pm [ UTC ]
