360 renders
Forums: 360 renders
Moderator: BK
360 renders
Postby Elele » Wed Jul 12, 2017 3:47 pm
Elele Wed Jul 12, 2017 3:47 pm
can we make 360 renders in Studio?
Thanks.
Elele
Re: 360 renders
Postby face_off » Sat Jul 15, 2017 2:01 pm
face_off Sat Jul 15, 2017 2:01 pm
You cannot render 360 degree images directly in the plugin. Instead, export the scene to ORBX and then open in Octane Standalone and change the camera type to Panoramic, and change the camera Projection to whichever VR format you require.
Re: 360 renders
Postby Elele » Sat Jul 15, 2017 3:50 pm
Elele Sat Jul 15, 2017 3:50 pm
Does the orbx retain all the materials or do I have to redo everything?
Elele
Re: 360 renders
Postby Isotemod » Sat Jul 15, 2017 7:55 pm
Isotemod Sat Jul 15, 2017 7:55 pm
Elele wrote:Does the orbx retain all the materials or do I have to redo everything?
Everything should be there linked correctly.
Isotemod
Re: 360 renders
Postby jcp » Thu Oct 26, 2017 10:39 pm
jcp Thu Oct 26, 2017 10:39 pm
Hi Paul,
Just following up on this and wondering if the panoramic camera is on the list of things to implement, as for the other octane plugins? I realise it is possible to export to standalone, add a pano camera, copy the daz camera settings etc. but it is a PITA, especially as every adjustment to the DAZ scene requires going through the whole process again (or am I missing a trick?).
James
jcp
Re: 360 renders
Postby face_off » Fri Oct 27, 2017 3:34 am
face_off Fri Oct 27, 2017 3:34 am
I'm sorry, but this is not something I can implement in the near future.
Re: 360 renders
Postby jcp » Tue Nov 07, 2017 12:34 am
jcp Tue Nov 07, 2017 12:34 am
Okay . . . could I clarify is this a technical limitation of DAZ or more a matter of priorities?
jcp
Re: 360 renders
Postby face_off » Tue Nov 07, 2017 12:49 am
face_off Tue Nov 07, 2017 12:49 am
It is not a limitation of DAZStudio. Adding an additional Octane camera type to the DAZStudio plugin is difficult given the way the plugin has been coded, so not something that I can do in the near future.
Re: 360 renders
Postby jcp » Wed Nov 08, 2017 9:34 am
jcp Wed Nov 08, 2017 9:34 am
That's good to know that it's possible, but disappointing that it is difficult - though I understand that you weren't responsible for the original code.
I'd appreciate it if you would consider implementing for the next major release.
And now I'll stop annoying you :)
jcp
Re: 360 renders
Postby alaman64 » Thu Aug 02, 2018 2:54 pm
alaman64 Thu Aug 02, 2018 2:54 pm
I also would be very interested in 360 renders. I understand that adding a new camera type would be difficult, but why can't we use an existing field that Daz uses to accomplish the same function? I ray can create 360 renders if under camera / lens / Lens Distortion Type / you choose Spherical .
I'm guessing if you pass that variable to octane, you should be able to accomplish what we're looking for?
Asus Z97-A / usb 3.1 - Windows 10 - 980 ti - Titan Black - Titan Z - Daz Studio
alaman64
Next
Return to DAZ Studio
Who is online
Users browsing this forum: No registered users and 25 guests
Fri Apr 26, 2024 5:04 pm [ UTC ]
