Moderator: BK
pinarer wrote:I tried to check the forum to find out an answer but couldnt find it, any idea how to solve the issue when the hair dont show up on Octane render?
Banti wrote:pinarer wrote:I tried to check the forum to find out an answer but couldnt find it, any idea how to solve the issue when the hair dont show up on Octane render?
I see two possible scenarios:
1) You are using strand based / dForce Hair. Those will not work in Octane at all. At least not yet, maybe the reworked plugin will implement this feature at some point.
2) You have something pluggine into your hair materials opacity channel that should be there, maybe an empty grey image pin. Make sure you dont apply the same material to all surfaces of the hair because they often have different opacity maps or dont have one at all. Copy the material and apply it to each surface separately.
Banti wrote:Strand based hair is definitly not supported yet. If you got to the plugin release thread here: viewtopic.php?f=44&t=77593
You can see that strand based hair is the first point under "known issues awaitung resolution"
Users browsing this forum: No registered users and 24 guests
