Export Rhino blocks instances to orbx
Forums: Export Rhino blocks instances to orbx
Postby A.Lopez » Thu Apr 07, 2022 6:38 am
A.Lopez Thu Apr 07, 2022 6:38 am
Hello,
I've created one tree in Rhino / Grasshopper that uses instances as leaves.
Now I would like to transform this tree in ORBX model, to reimport it later as Proxy ORBX in Rhino. The problem is that if I export the model in OBJ or FBX to create an ORBX file in Octane standalone, I lose the instances (each leaf is exploded) and I lose the big deal of leaves as instances.
Unfortunately, I think to know already the answer...but I ask anyway if some genius has one solution or workaround to maintain the "instances inside instances".
Roy
A.Lopez
Re: Export Rhino blocks instances to orbx
Postby face_off » Fri Apr 08, 2022 2:11 am
face_off Fri Apr 08, 2022 2:11 am
I don't think the plugin export functionality is setup to do that. It is designed to export the scene for rendering in Octane Standalone. You really need a tree model (in OBJ or ORBX format) and then use that on the Block Instance (using the plugin Geometry->Load OBJ/ORBX buttons).
Postby A.Lopez » Fri Apr 08, 2022 10:57 am
A.Lopez Fri Apr 08, 2022 10:57 am
ok, thanks,Roy
A.Lopez
Return to Rhinoceros 3D
Users browsing this forum: No registered users and 31 guests
Sat Apr 27, 2024 8:29 am [ UTC ]
