It will be a couple of days after the next Octane release (assuming there are no serious issues found with that Octane release).Any idea on the release date for rhino 6 octane plugin?
I wonder if this is because the nodegraph material is being using on as instance? Would you be able to send me a sample scene which demonstrates this problem pls?will it be possible in Rhino6 to keep the octane node texture visible in rhinos render window?
I find when I start using node graphs the textures disappears from my rhino viewport.
Even with bump map, once I have applied that to a texture the texture shown in the rhino viewport turns purple?
This is useful because at times I may choose to do viewcaptures or do diagrammatic renders through rhino.
Image below shows the nodegraph applied to the leafs.
- The Replicate proxy function should now be quicker
- Replicated ORBX proxies are now only loaded once into the Octane scene rather than multiple times. This will result in a quicker load time, and less VRAM being used
Which version of Rhino pls Andreas?I just tried to install the new build, however I get this error message :
There are no toon lights - since there is no way to associate a Rhino light with an Octane toon light. It only works with the Camera Light mode as per the release notes.I can find the toon material but can't seem to find toon light. Could you tell me where it's located
Users browsing this forum: No registered users and 17 guests
