OctaneRender 3 for Rhino (OBSOLETE)
Forums: OctaneRender 3 for Rhino (OBSOLETE)
Re: OctaneRender 3 for Rhino (TEST and STABLE)
Postby face_off » Tue Jul 11, 2017 1:52 am
face_off Tue Jul 11, 2017 1:52 am
What I do not really understand is that I always thought that the thumbnail renderings are generated by the octane engine which would of course make sense ... if this is so than I wonder why I is not possible to influence the quality/speed of this...
Rhino calls a "Generate Thumbnail" function in the plugin, and the plugin then requests the thumbnail from Octane. This is a "blocking" call - so while the thumbnail is being generated, no other UI functions are available (thus the slow load time).
Postby Igor_K » Fri Aug 18, 2017 10:55 pm
Igor_K Fri Aug 18, 2017 10:55 pm
HI,
any updates on plugin for Rhino 6 beta?
Igor_K
Postby face_off » Sun Aug 20, 2017 12:46 pm
face_off Sun Aug 20, 2017 12:46 pm
I have a test version running now. I will release it in the next day or two once I add Octane 3.07 support.
Postby face_off » Tue Aug 22, 2017 11:15 am
face_off Tue Aug 22, 2017 11:15 am
Below is a pre-release of the Octane 3.07 build of the plugin. It contains a number of internal changes, so I would appreciate if users could check this release runs OK pls.
3.7.0.85
- Compiled with Octane 3.07 TEST 3. See viewtopic.php?f=33&t=62636 for details.
https://render.otoy.com/customerdownloads/plugins/0e/37/0d/bc/OctaneRenderForRhino5_3_7_0_85.rhi
If no issues are reported in the next few days, I will release the Subscription and Rhino6 versions.
Postby Bendbox » Tue Aug 22, 2017 12:21 pm
Bendbox Tue Aug 22, 2017 12:21 pm
Hi Paul,
I have yet to play around with Rhino V6, however, I was wondering if you were far enough along with the Octane plugin for V6 yet to know what enhancements might have developed for Octane when using Rhino V6 over V5?
For example -- if it would be possible to avoid having to reload the scene for every frame when doing an animation? I've been exporting to the stand alone to avoid this when working with larger scenes and was hoping that with RhinoV6 that same capability would be possible to avoid having to export to the stand alone.
Or, if RhinoV6 will allow Object Motion blur to work within Rhino as well when animating?
Clipping Masks working with Octane in RhinoV6?
Thanks Paul, I hope all is will with you,
Ryan
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
Bendbox
Postby face_off » Wed Aug 23, 2017 12:42 am
face_off Wed Aug 23, 2017 12:42 am
I have been focusing on just getting the plugin to run in Rhino6. The RhinoCommon API has changed sufficiently to require a lot of code changes just to get the plugin to run.
I don't know, but my best guess is that Rhino6 will not allow this - since it would be a fundamental shift in how the Rhino API provides geometry information (ie. it is currently in World Space, and would need to change to Local Space).
Again - I doubt Rhino6 will support this - since it would need the geometry transform of each geometry item to be provided by the Rhino API.
McNeel said this would be possible in Rhino6, but I'm not sure yet if it has been added.
Postby Bendbox » Wed Aug 23, 2017 12:19 pm
Bendbox Wed Aug 23, 2017 12:19 pm
Thanks for the feedback Paul.
Ryan
Bendbox
Postby Refracty » Sat Aug 26, 2017 8:51 am
Refracty Sat Aug 26, 2017 8:51 am
Hi Paul,
I have a question about the new V3.07 Standalone feature:
"Added new texture node "Instance color" and "Instance range" to use the instance IDs in textures/materials."
Does that mean that the instances that I use can contain their own, individual diffuse colors?
How would that work in the Rhino plugin?
I often have multiple cars with unique car paints and to save memory I need to use instances with individual diffuse colors.
Thank you
Cheers
Nando
Refracty
Postby face_off » Sat Aug 26, 2017 11:57 am
face_off Sat Aug 26, 2017 11:57 am
That is correct.
I'm not sure if it would work with the Rhino plugin. I will need to see if there is a way to tag each instance with an instance id, however I suspect this might not be possible.
Postby Refracty » Sat Aug 26, 2017 7:45 pm
Refracty Sat Aug 26, 2017 7:45 pm
Thank you for the fast reply.
It would be so useful if this would work with Rhino.
With more then 50 cars in one scene, scratching on the poly limit of 80M polys it is the solution to the memory limitation.
Do think other Octane plugin developers will have a workaround that could also be adapted for Rhino and the instance ids?
Refracty
PreviousNext
Return to Rhinoceros 3D
Users browsing this forum: No registered users and 16 guests
Fri Apr 26, 2024 7:59 am [ UTC ]
