Group Materials on Import.
Forums: Group Materials on Import.
Postby BillyRaygun » Mon Sep 27, 2010 3:19 am
BillyRaygun Mon Sep 27, 2010 3:19 am
Is there a way to consolidate objects with the same material? For example, I have 250 plus objects with the same material. When I import the model into Octane, it seems as a material node is created for each object. So I end up with 250 duplicates of the same material.
I'm using Rhino 4. Perhaps Rhino 5 export options solve this issue? Anyway, it's a bit overwhelming and very difficult to manage so many materials/objects when they all have the same materia
Regards,
Billy Raygun
Billy Raygun Design, Inc. | A Trade Show Agency | http://www.billyraygun.com
Windows 7 | 64-bit | 8gb | OctaneRender 1.024 beta2.46b CUDA 3.2 | NVIDIA 267.26
BillyRaygun
Re: Group Materials on Import.
Postby Nostromo » Mon Sep 27, 2010 9:13 am
Nostromo Mon Sep 27, 2010 9:13 am
/ Moved to the rhino plug-in forum /
Nostromo
Postby SamPage » Mon Sep 27, 2010 1:34 pm
SamPage Mon Sep 27, 2010 1:34 pm
BillyRaygun wrote:Is there a way to consolidate objects with the same material?
Yes, currently the plug-in uses the default Rhino OBJ exporter, V5 solves these issues. The plan is to have the plug-in use its own obj exporter to give more flexibility and be able to work around such issues. I'm not sure when I will have that completed however.
Sam
Win 7 64bit | 2x GTX 285 | i7 920 | ASUS P6T Deluxe | 12GB
SamPage
Postby BillyRaygun » Mon Sep 27, 2010 7:29 pm
BillyRaygun Mon Sep 27, 2010 7:29 pm
Thanks Sam! That is good news. I'll switch to the Rhino 5 beta when I know I'll be rendering with Octane.
BillyRaygun
Postby **STK** » Tue Sep 28, 2010 12:38 pm
**STK** Tue Sep 28, 2010 12:38 pm
Convert the nurb geometry with the same material into mesh. Then join all new mesh geometry into one object.Attach the material.Export with Octane
Have Fun!
Dual Xeon E5540 CPU 2.53 - 1x GTX470 - win7 64 -12GB ram
**STK**
Postby tom_holly » Thu Jun 23, 2011 12:32 pm
tom_holly Thu Jun 23, 2011 12:32 pm
I've uploaded a script to remove and sort the duplicate materials in MTL files when exporting OBJ files from Rhino 3D.
It works for Rhino 4. It may or may not work for other versions.
This is not fully tested, so use at your own risk.
You may post any bugs to me here: http://www.refractivesoftware.com/forum/viewtopic.php?f=41&t=7044
http://rhino-3d-obj-mtl-fix.zzl.org/
Cheers, Tom
AMD Athlon(tm) II X4 640 @ 3.0 HGz | 4.00 GB | Octane beta 2.44 | Rhino V4 SR9 | Windows Vista x64 | GTX 570
tom_holly
Return to Rhinoceros 3D
Users browsing this forum: No registered users and 14 guests
Fri Apr 26, 2024 1:03 am [ UTC ]
