does Octane plugin for Rhino support embedding textures inside rhino files? I have a octane material that is using texture map for mix material node. I try to save rhino file with "save textures" feature on. But when I try to open the rhino file again it asks me to re-link the texture file (I renamed original texture file to test if this method is working). I know I can just re-link the texture, but I want to share the file with the other team and looking for a "just open and render solution"
Hi - the Octane plugin is expecting all texturemap image file to be a physical file on the filesystem, with the same filename each time the .3dm file is opened. I haven't tried embedded Rhino textures, but my guess is that they would not work.
