Black Depth Fog
Forums: Black Depth Fog
Black Depth Fog
Postby lstudios3d » Mon Mar 22, 2021 7:31 pm
lstudios3d Mon Mar 22, 2021 7:31 pm
I have a close-up product with a gridded ground going all the way off into the distance. I want to have everything fade off into a black background. Basic LW I can turn the fog off and dial it in and turn it black but I struggle to get the Minimum distance set up and also have the fog set to black as it doesn't even show up when it's all black. Is there a better way to do this in render?
lstudios3d
Re: Black Depth Fog
Postby juanjgon » Wed Mar 24, 2021 7:26 pm
juanjgon Wed Mar 24, 2021 7:26 pm
I'm not sure, to be honest, but I suppose that this should be possible using an environment medium node. If you can share an example scene with your workflow I could take a look at it here. This should also be easy to do in post using the z-depth pass.
juanjgon
Return to Lightwave 3D
Users browsing this forum: No registered users and 21 guests
Fri Apr 26, 2024 4:35 am [ UTC ]
