OctaneRender 4.05 for LightWave Production build 4.05.0.0
Forums: OctaneRender 4.05 for LightWave Production build 4.05.0.0
Postby juanjgon » Sun Sep 01, 2019 6:06 pm
juanjgon Sun Sep 01, 2019 6:06 pm
This is the latest stable release of the OctaneRender™ 4.05 for LightWave™ plugin version 4.05.0.0, available for LightWave 11.6, 2015.3, 2018.0 and 2019.x Windows x64 and OSX. This build has been compiled using the Octane 4.05 core.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
New features
To learn more about the new features and improvements of OctaneRender 4, please check out our blog post, but this a quick list of the main new features that have been added:
  • Overhauled geometry engine that dramatically reduces compilation times.
  • Support for out-of-core geometry.
  • AI Light: Improved sampling of emitters, which is a lot more effective than the old method if you have many small emitters that have only a fairly local effect.
  • AI Denoiser: Cleans up your render, which can dramatically cut render times.
  • Global light inclusion/exclusion.
  • Light linking: Allows the inclusion/exclusion of light IDs in the object layer nodes, which can be used to control the direct influence of emitters on objects.
  • Universal material: Merges the properties of the diffuse, glossy, specular and metal materials into one material.
  • UDIM support via the new image tile mode in the texture image node.
  • Dirt support in the info channel passes / kernel.
  • Overall performance improvements in the render engine and in loading HDR and OBJ files.
  • Support to capture direct and indirect light separately in the light render passes.
  • Support for emission on sphere primitives.
  • Planetary environment node.
Release 4.05.0.0 regular license
https://render.otoy.com/customerdownloa ... _Win64.zip
https://render.otoy.com/customerdownloa ... ve_OSX.zip
Release 4.05.0.0 subscription license
https://render.otoy.com/customerdownloa ... n64_vr.zip
https://render.otoy.com/customerdownloa ... OSX_vr.zip
Release 4.05.0.0 demo builds
https://render.otoy.com/plugindownloads ... 4_demo.zip
https://render.otoy.com/plugindownloads ... X_demo.zip
Standalone 4.05 version for the network rendering nodes
https://render.otoy.com/customerdownloa ... 05_win.exe
Release Notes:
RELEASE 4.05.0.0
* PLUGIN FEATURES AND FIXES:
- Added a workaround to try to fix the arbitrary range type sequence rendering.
RELEASE 4.04.0.1 (VR SUBSCRIPTION ONLY)
- Addressed the support of the network rendering in the vr subscription builds.
RELEASE 4.04.0.0
* OCTANE FEATURES AND BUGS FIXED:
- Fixed a dongle activation issue.
- Fixed exporting scenes from plugins that contain animated transforms with zero matrices.
- Fixed a crash when stopping render, and then previewing a material in the node stack. This also caused crashes in plugins that use the same mechanism to render thumbnails and material preview tiles.
- Fixed a crash during activation on some machines with RAID setups.
- Fixed denoiser black pixels.
RELEASE 4.03.0.0
* PLUGIN FEATURES AND BUGS FIXED:
- Fixed the problems related to the wrong ordering or mising UDIM textures.
- New volumetrics phase node that can be used to animate this parameter in the volume and scattering medium nodes.
- Fixed black pixels from denoiser.
- Added sheen and coating normal and bump maps.
- Fixed volume step length being locked to 4 when using absorption or scattering medium with alpha shadows disabled.
- Fixed caustic blur for clear coat layer of universal material.
- Fixed "visible on specular" emitter option when used with universal material.
- Fixed black material render on Octane BRDF when using 0 roughness.
- Allow greyscale images as opacity maps, as it was in V3.
- Fixed "affects alpha" option of specular materials when "keep environment" is enabled. (fixed the refraction pass erroneously including the environment in that case)
- Fixed universal material (transmission only) with roughness 0 rendering incorrectly.
- Fixed excessive noise in universal material when used with a medium node.
- Increased max number of alpha intersections, which fixes some scenes that have a lot of alpha maps.
Happy rendering,
Your OTOY Team
juanjgon
Re: OctaneRender 4.05 for LightWave Production build 4.05.0.0
Postby pixym » Mon Sep 02, 2019 1:45 am
pixym Mon Sep 02, 2019 1:45 am
Hi Juanjo,
Great thanks !
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - 32GB - 2 GTX 1080 TI - Win 10 64
NET RENDER : MB Biostar TB250-BTC Pro - Celeron 2C/2T - Open "Mining" Rig - 2 RTX 2080 TI - Win 7
pixym
Postby EBD3D » Mon Sep 16, 2019 9:54 pm
EBD3D Mon Sep 16, 2019 9:54 pm
Grand Merci ;)
EBD3D
Postby FredRan » Fri Sep 27, 2019 1:40 pm
FredRan Fri Sep 27, 2019 1:40 pm
Hi Juanjo,
I really miss the material preview in lightwave 2019 . Do you plan to do something about this ?
Thx !
FredRan.
FredRan
Postby juanjgon » Fri Sep 27, 2019 4:39 pm
juanjgon Fri Sep 27, 2019 4:39 pm
FredRan wrote:Hi Juanjo,
Thx !
FredRan.
Unfortunately, LightWave has removed the shaderballs from the materials and node editor panels, so I need to check if something can be done with the new LW2018 preview option. I'm not even sure how open is this new system to external renderers.
juanjgon
Postby BorderLine » Mon Oct 21, 2019 6:13 am
BorderLine Mon Oct 21, 2019 6:13 am
Hi JuanJo !
Any news for new version ?
BorderLine
Postby juanjgon » Mon Oct 21, 2019 12:21 pm
juanjgon Mon Oct 21, 2019 12:21 pm
Nope, the plugin is updated with the current 4.05 Octane core, that is the latest one, so probably there is not going to be a new version unless a new core is released.
juanjgon
Postby KVNOODLES » Fri Oct 25, 2019 6:59 pm
KVNOODLES Fri Oct 25, 2019 6:59 pm
Hi Juan,
Is it possible to have some Envelop button for the hair width base and tip in the Octane Object Properties ?
It could be very cool and useful...
Oh I forget !...
Coherent Ratio doesn't have any nodal input or envelop entry in all PMCs available. Strangely, Path Term Ratio have one...
Hope this isn't the hell to implemant these little things on a future release.
KVNOODLES
Postby juanjgon » Sun Nov 10, 2019 10:32 am
juanjgon Sun Nov 10, 2019 10:32 am
I've added the envelop button for the hair width base and tip in the Octane Object Properties in the next Octane 2019.1.x build.
juanjgon
Postby KVNOODLES » Tue Nov 12, 2019 9:50 pm
KVNOODLES Tue Nov 12, 2019 9:50 pm
Faster than light...
Thanks Juan, very cool and fast...Hope you'll integrate it in a future 4.0x release because we are in production and we can't switch to the 2019 actually...
KVNOODLES
Next
Return to Releases
Fri Apr 26, 2024 6:03 am [ UTC ]
