Plane displacement and instance placement
Forums: Plane displacement and instance placement
Postby lamerehic » Wed Jan 09, 2019 4:26 pm
lamerehic Wed Jan 09, 2019 4:26 pm
I am working on a ground plane that i displace in octane, and i would like to place dirt and thing on top of it...
I got a plane on a layer and a bunch of point for the instances.
is there a way doing this all in octane, or must i displace the mesh in LW modeler and conform points on the second layer in order to have well placed instance?
Doest the raycast node work in octane and how?
lamerehic
Re: Plane displacement and instance placement
Postby frankmci » Wed Jan 09, 2019 5:52 pm
frankmci Wed Jan 09, 2019 5:52 pm
This may be what you are looking for:
https://www.virtual-lands-3d.com/scatte ... ender.html
Technical Director - C4D, Maya, AE, - Washington DC
frankmci
Postby lamerehic » Wed Jan 09, 2019 7:07 pm
lamerehic Wed Jan 09, 2019 7:07 pm
Thanks for the response, but i am affraid we don't have a scatter on Lw Octane
lamerehic
Postby frankmci » Wed Jan 09, 2019 8:21 pm
frankmci Wed Jan 09, 2019 8:21 pm
Sorry, It's been more than 20 years since I used Lightwave. I thought LW let you offset instances based on a texture map. As long as you can generate your instances from the base, pre-displaced geometry (or a copy of it), then drive the offset position of the instances from that texture map or a version of it, you should be able to do the same thing. Good luck!
frankmci
Postby juanjgon » Thu Jan 10, 2019 12:02 am
juanjgon Thu Jan 10, 2019 12:02 am
lamerehic wrote: is there a way doing this all in octane, or must i displace the mesh in LW modeler and conform points on the second layer in order to have well placed instance?
I'm afraid that currently the plugins can't have access to the Octane displaced mesh, so as you say you are going to need a mesh displaced using the LW native displacement system to place the instances.
juanjgon
Postby lamerehic » Thu Jan 10, 2019 7:15 am
lamerehic Thu Jan 10, 2019 7:15 am
Ok,
thanks, i got it, was simple....
as you said displace the point layer with nodal and done....
lamerehic
Return to Lightwave 3D
Users browsing this forum: No registered users and 22 guests
Fri Apr 26, 2024 4:49 am [ UTC ]
