Object Dissolve
Forums: Object Dissolve
Object Dissolve
Postby jang2235 » Wed Jun 27, 2018 2:33 am
jang2235 Wed Jun 27, 2018 2:33 am
I'm working on an animation using Object Dissolve.
In the octane render, I understood that I used the Enable State to hide the object.
I set On and Off using Enable state Graph Editor.
I set the Rendering Scene Update mode to "Update Scene" mode on the Octane render target and ran the render, but the object did not appear.
So I set it to "Full scene reload" mode and it is working.
This mode works normally, but it seems to take a long time to load all the scenes for each frame.
Is there any way to fix it without "Full scene reload" mode?
jang2235
Re: Object Dissolve
Postby promity » Wed Jun 27, 2018 7:24 am
promity Wed Jun 27, 2018 7:24 am
Maybe you should try to animate the opacity channel in the surfaces? You can also make an object invisible by dramatically changing its size (step curve in the Graph Editor) etc etc
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
Re: Object Dissolve
Postby juanjgon » Wed Jun 27, 2018 9:09 pm
juanjgon Wed Jun 27, 2018 9:09 pm
Yes, sorry, the "Enable State" only can be animated in full scene reload mode. In any case, the @promity workarounds could work if you need to dissolve objects in update mode.
-juanjo
juanjgon
Return to Lightwave 3D
Who is online
Users browsing this forum: No registered users and 22 guests
Fri Apr 26, 2024 1:03 pm [ UTC ]
