by drako3d » Sun Oct 22, 2017 8:02 pm
drako3d
I have always activate the volume update button in the render target node if you use only "update scene"...Also sometimes i use the full reload scene in the render node.
I have also the volumetrics update on when i use volumetrics.
Juan you wrote me the following.....
"Yes, to render VDB sequences you need to use the $F token in the filename, that is replaced by the frame number using four digits. For example, if your VDB file name is smoke_$F.vdb, the plugin will load the file smoke_0056.vdb if you are in the frame 56."
I cant understand. When i export from blender i have a sequence of files named just Smoke_0000.vdb, Smoke_0001.vdb, Smoke_0002.vdb and so on. When i upload them with the volumetrics object properties i choose the first one as we do for the sequences. That method does not work. If i get it right from your comment i have to rename all the files of the sequence from Smoke_0000.vdb to
Smoke_$F.vdb or just the first one?
Can you help me please.
