Randomly Change UV on Instances
Forums: Randomly Change UV on Instances
Postby 3dreamstudios » Fri Sep 01, 2017 4:00 pm
3dreamstudios Fri Sep 01, 2017 4:00 pm
I see the Random Color Texture node which has an output of texture (dark green) and the LW native Random Scalar which has number output (light green).
On a texture image the UV Translate is a light green (number) I want to use the RandomColor Texture that changes each INSTANCE of an object but want to plug that into the NUMBER values. Is there a way to do this with other nodes? Gradient or other tool?
If I plug the Octane RandomColor Texture into the Power of a texture node I get each instance to be a different value/brightness of the texture, which is nice...but want to change the UV position slightly so everything doesn't look the same.
Thoughts?
3dreamstudios
Re: Randomly Change UV on Instances
Postby juanjgon » Mon Sep 04, 2017 10:56 am
juanjgon Mon Sep 04, 2017 10:56 am
I'm afraid that this is not possible in Octane currently, or at least I can't figure how to modify the instances UVs.
juanjgon
Postby CANDITO » Thu Sep 28, 2017 10:51 am
CANDITO Thu Sep 28, 2017 10:51 am
You could make 3 different uvs on your objects
and use this 3 uvs on your texture nodes to have
a bit of a randomness (it will be limited to 3 uvs
but it will always be better than having only one
on every instance)
Olivier
CANDITO
Postby 3dreamstudios » Thu Sep 28, 2017 12:28 pm
3dreamstudios Thu Sep 28, 2017 12:28 pm
CANDITO wrote:Hi,
on every instance)
Olivier
Thats an interesting idea. I'll look into that setup. Thanks for the idea!
3dreamstudios
Return to Lightwave 3D
Who is online
Users browsing this forum: No registered users and 18 guests
Fri Apr 26, 2024 9:53 pm [ UTC ]
