juanjgon wrote:What happens if you set only 2 or 3 steps in the motion blur (change this parameter in the LW instance generators and in the Octane render options)?
This problem sounds to me to something related to have a lot of instances in near de same place (high instances density, with two or more instances in the same place), or to have very long motion blur trails. Perhaps you could play with the instances relax parameter, to modify a bit the instances distribution, and as I said before, use only 2 or 3 steps motion blur.
You could also try to render the scene using a bit less motion blur length, to see what happens.
I've seen also problems like this if you have 0 scale instances in one or more frames. Is it possible that any instance could have a 0 scale?
In any case, if you can send me the scene, I could try to find a workaround for the problem.
hi juanjo
i have here the same problem with a scene with tones of instances. With 3.06.04 this is happen...
00:02:51 (0171.74) | ... Check sizes for IPR
00:02:51 (0171.74) | ... Reading frame buffer
00:02:51 (0171.76) | Reading preview image successfully
00:02:51 (0171.98) * OCTANE API MSG: CUDA error 716 on device 0: misaligned address
00:02:51 (0171.98) * OCTANE API MSG: -> kernel execution failed(report)
00:02:51 (0171.98) * OCTANE API MSG: -> failed to launch kernel(ptBrdf2)
00:02:51 (0171.98) * OCTANE API MSG: device 0: path tracing kernel failed
00:02:51 (0171.98) * OCTANE API MSG: device 0: detected an error on render device! trying to recover...
00:02:51 (0171.98) * OCTANE API MSG: -> failed to deallocate device memory
00:02:51 (0171.98) * OCTANE API MSG: -> could not get memory info
00:02:52 (0172.06) * OCTANE API MSG: -> could not get memory info
00:02:52 (0172.06) * OCTANE API MSG: CUDA error 716 on device 3: misaligned address
00:02:52 (0172.06) * OCTANE API MSG: -> failed to deallocate device array
00:02:52 (0172.06) * OCTANE API MSG: -> failed to deallocate device memory
00:02:52 (0172.06) * OCTANE API MSG: -> failed to deallocate pinned memory
00:02:52 (0172.06) * OCTANE API MSG: -> failed to unregister pinned memory
00:02:52 (0172.06) * OCTANE API MSG: -> failed to unload module
00:02:53 (0173.77) * OCTANE API MSG: CUDA error 716 on device 0: misaligned address
00:02:53 (0173.77) * OCTANE API MSG: -> failed to bind device to current thread
00:02:53 (0173.77) * OCTANE API MSG: device 0: failed to initialize resources
00:02:53 (0173.77) * OCTANE API MSG: device 0: failed to recover - giving up and switching device to failed
00:02:53 (0173.77) |
00:02:53 (0173.77) | ++++++++++++++++++++++++++
00:02:53 (0173.77) | +++ IPR RENDER FAILURE +++ processing the failure callback
00:02:53 (0173.78) | IPR: reset image callback
00:02:53 (0173.78) | IPR: wait for the getPreviewImage function
00:02:53 (0173.88) | IPR: free the OpenGL buffers
00:02:53 (0173.88) | IPR: rendering done
00:02:54 (0174.05) * OCTANE API MSG: CUDA error 716 on device 2: misaligned address
00:02:54 (0174.05) * OCTANE API MSG: -> failed to bind device to current thread
00:02:54 (0174.05) * OCTANE API MSG: device 2: failed to initialize resources
00:02:54 (0174.05) * OCTANE API MSG: device 2: failed to recover - giving up and switching device to failed
00:02:54 (0174.08) * OCTANE API MSG: CUDA error 716 on device 1: misaligned address
00:02:54 (0174.08) * OCTANE API MSG: -> failed to bind device to current thread
00:02:54 (0174.08) * OCTANE API MSG: device 1: failed to initialize resources
00:02:54 (0174.08) * OCTANE API MSG: device 1: failed to recover - giving up and switching device to failed
00:02:54 (0174.09) * OCTANE API MSG: CUDA error 716 on device 3: misaligned address
00:02:54 (0174.09) * OCTANE API MSG: -> failed to bind device to current thread
00:02:54 (0174.09) * OCTANE API MSG: device 3: failed to initialize resources
00:02:54 (0174.09) * OCTANE API MSG: device 3: failed to recover - giving up and switching device to failed
00:03:03 (0183.48) | IPR: close the IPR preview window
00:03:03 (0183.48) | IPR: finish render thread command
00:03:03 (0183.48) | IPR: abort render thread command
00:03:03 (0183.48) | Stop rendering scene
00:03:03 (0183.87) | IPR: abort render thread command finished
00:03:03 (0183.87) | Close and free scene, free buffer: 0, reset scene: 1
00:03:03 (0183.87) | ... setRenderTargetNode(NULL)
00:03:03 (0183.87) | ... update()
00:03:03 (0183.87) | ... getRootNodeGraph()->clear()
00:03:04 (0184.46) | Scene closed
00:03:04 (0184.46) | IPR: free the snapshots system
00:03:04 (0184.46) | IPR: IPR preview window closed
if i downgrade to V 3.05.03 the scene would render perfect
snip lwguru
