Fall Off question + new options in V3
Forums: Fall Off question + new options in V3
Postby CANDITO » Thu Feb 02, 2017 2:29 pm
CANDITO Thu Feb 02, 2017 2:29 pm
Hello everyone,
i'm trying to have more control on the falloff texture,
i need a texture that is very dark in the borders (on a cylinder)
on a few millimeters and which gets very light then.
With the actual falloff, the gradient is too soft and i can achieve this effect
(for example with the native LW gradient node i would put 2 dark keys near the grazing and play with them)
Also is there a tutorial or help regarding the new options of the falloff node in V3?
Thanks a lot for your help ;)
Olivier
CANDITO
Re: Fall Off question + new options in V3
Postby juanjgon » Thu Feb 02, 2017 6:47 pm
juanjgon Thu Feb 02, 2017 6:47 pm
The falloff node "Falloff Skew Factor" parameter should help. It controls the falloff softness.
juanjgon
Postby CANDITO » Thu Feb 02, 2017 10:07 pm
CANDITO Thu Feb 02, 2017 10:07 pm
Thanks Juanjo,
I know but it still gets too soft, or not precise enough to control the falloff
in most of the cases (in the glazing angle mostly)
I tried to put a LW gradient node connected to the procedural input
but it doesn't seems to do anything, but i guess it's normal...
I will deal with a UV map and a texture for the moment,
if you think of anything else that could help
you're very welcome :)
Thanks again
Olivier
CANDITO
Postby 3dreamstudios » Fri Feb 03, 2017 9:30 pm
3dreamstudios Fri Feb 03, 2017 9:30 pm
Seems like I use to do a fake frensel with a gradient and grazing angle or something in LW Native. Since the falloff node is just a black and white node output into the specular. Is there a way that a gradient could be plugged into the specular? May be a limitation currently in Octane. Since Octane as I understand it needs to be real world stuff, not faked. Would be nice to have more control here though....
3dreamstudios
Postby 3dreamstudios » Fri Feb 03, 2017 9:42 pm
3dreamstudios Fri Feb 03, 2017 9:42 pm
Maybe something like this could help?
3dreamstudios
Postby CANDITO » Thu Feb 16, 2017 6:30 pm
CANDITO Thu Feb 16, 2017 6:30 pm
Thanks 3dreamstudios !
sorry for the late answer :)
Olivier
CANDITO
Return to Lightwave 3D
Users browsing this forum: No registered users and 22 guests
Sat Apr 27, 2024 1:58 am [ UTC ]
