Lightwave 3D Plugin v0.2
Posted: Fri Jul 30, 2010 10:38 am
Comes with two .obj exporters - you can switch between the two inside the Octane Exporter GUI.
!Please make sure you read both the offical manual on Plugin<->Octane workflow and the readme.txt inside this package before using this plugin.
If you have any issues please give me information what your export settings are and what you're exporting. You can reach me on skype 'walfridson' or at my mail if you want faster contact or sending me files.
v0.2e changes: sets autokey to true when rendering
v0.2d changes: bug fix
v0.2c changes: logfile output
v0.2b changes: removed 3-4 point limit, didnt know octane supports more...
v0.2 changes: Octane OBJ Export rewrite. Have to modes, "Normal" or "Fast". Fast is a bit more dirty but might actually fix UV problems if you have any. I recommend using "Fast"
- "Lightwave HC OBJ Exporter" is Lightwave Layout internal obj writer only available in Lightwave HC (build 2013 or later)
- "Octane OBJ Export" is written by me and windows only. For Lightwave 9 or later.
