Ray Epsilon issue
Forums: Ray Epsilon issue
Ray Epsilon issue
Postby Pavlov » Fri Jul 23, 2021 2:05 am
Pavlov Fri Jul 23, 2021 2:05 am
Hi, in a very large scene (60km) it seems Ray epsilon allows correct rendering of details close to camera OR volumetric in the distance.
Somehow it seems Octane cannot put same attention on very small and very large scale and this is a very important limitation.
Is there a way to force octane to care about everything at maximum quality ?
Here you see how i get banding in distant volumetric OR bad intersection line between water and sand.
Paolo
I7 960 3.2 GHZ - 6GB ram - GTS 250 display only - Asus GTX 470
Pavlov
Re: Ray Epsilon issue
Postby juanjgon » Fri Jul 23, 2021 8:43 am
juanjgon Fri Jul 23, 2021 8:43 am
I don't think so. Trying to render small details in a 60km scene is really hard due to the single-precision floating math limitations. In these cases rendering two passes to comp them later can be the only real solution.
juanjgon
Postby pixym » Sun Jul 25, 2021 1:54 am
pixym Sun Jul 25, 2021 1:54 am
Hi Paolo, I would try to to downscale the entire scene in Layout. Maybe ?
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - 32GB - 2 GTX 1080 TI - Win 10 64
NET RENDER : MB Biostar TB250-BTC Pro - Celeron 2C/2T - Open "Mining" Rig - 2 RTX 2080 TI - Win 7
pixym
Return to Lightwave 3D
Users browsing this forum: No registered users and 34 guests
Fri Apr 26, 2024 6:42 am [ UTC ]
