Octane buffer pixel value read out?
Posted: Mon Jun 05, 2023 8:41 pm
by Dingbat
is there a way to check pixel values in the buffer when rendering?
Re: Octane buffer pixel value read out?
Posted: Mon Jun 05, 2023 10:46 pm
by face_off
Hi - you can either use the octane.copyRenderToClipboard command and paste into Gimp, Photoshop, etc. Or I can add a function to the python interface of the plugin to allow you programmatic access to the render buffer.
Posted: Tue Jun 06, 2023 12:31 am
by elsksa
face_off wrote:(...) octane.copyRenderToClipboard command and paste into Gimp, Photoshop, etc.
That, while viable, would limit to integer encoding/file format (conformed to output destination) "picked values".
Posted: Tue Jun 06, 2023 5:42 am
by face_off
elsksa wrote:That, while viable, would limit to integer encoding/file format (conformed to output destination) "picked values".
Sorry, I am unclear what you are saying here. The current format that is saved to the clipboard is QImage::Format_RGB32 (https://doc.qt.io/qt-5/qimage.html#Format-enum). In theory any of the formats could be used, although I have not tried them.
Posted: Wed Jun 07, 2023 1:20 am
by elsksa
Thank you for the elaboration.
I was making the assumption that it was on-par with the Copy-To-Clipboard from Octane-Standalone, limited to a PNG file format (integer "LDR"). I suppose it is rather the equivalent to the nearby icon (quick "save the current render to disk").
Posted: Wed Jun 07, 2023 6:03 am
by face_off
Yes, the plugin is also copying the render to the clipboard in LDR format.
Posted: Wed Jun 07, 2023 6:59 pm
by Dingbat
face_off wrote:Hi - you can either use the octane.copyRenderToClipboard command and paste into Gimp, Photoshop
that's what i currently do but it's a bit clunky when you want to quickly check and adjust a few colours, or check clipping
not the end of the world but would be very handy to have
or a histogram?
Posted: Wed Jun 07, 2023 8:29 pm
by elsksa
or a histogram?
There are no such issue as "clipping" with a proper color pipeline.
As it's quite long to unpack everything, this page covers it, and this one.
Posted: Mon Jun 12, 2023 5:22 pm
by Dingbat
elsksa wrote:There are no such issue as "clipping" with a proper color pipeline
thanks
i get that but sometimes Octane tonemapping (in the frame buffer) is all i need and more often than not i prefer it to both ACES and Filmic tonemapping
i found this tool from MS - not ideal but at least i can check things much more quickly:
https://learn.microsoft.com/en-us/windo ... lor-picker
