displacement - mix 2 textures?
Forums: displacement - mix 2 textures?
Postby Dingbat » Mon Feb 14, 2022 1:04 pm
Dingbat Mon Feb 14, 2022 1:04 pm
what am i doing wrong here?
i'm trying to combine 2 textures as displacement textures. i tried Mix, Multiply and Add but in all cases nothing happens (the displacement is ignored)
if i use the textures individually then the mesh is displaced as expected
Dingbat
Re: displacement - mix 2 textures?
Postby face_off » Tue Feb 15, 2022 3:40 am
face_off Tue Feb 15, 2022 3:40 am
Hi - use the Baking Texture to bake the texture to a physical file, which can then be plugged in to the Displacement node.
Postby Dingbat » Wed Feb 16, 2022 8:39 am
Dingbat Wed Feb 16, 2022 8:39 am
i was hoping for something a bit more interactive :)
is this an Octane limitation (not the plugin)?
Dingbat
Postby funk » Wed Feb 16, 2022 8:45 am
funk Wed Feb 16, 2022 8:45 am
It's interactive. Plug your mix texture into the baking texture node, then the output to the displacement node
https://docs.otoy.com/ModoH/ModoPluginM ... exture.htm
Win10 Pro/ Ryzen 5950X / 128GB / RTX 4090 / MODO
funk
Postby funk » Wed Feb 16, 2022 8:50 am
funk Wed Feb 16, 2022 8:50 am
There are 2 displacement nodes in Octane.
Texture displacement - fast, using voxels, but limited to single images (or baking node). Can have artifacts/leaks
https://docs.otoy.com/ModoH/ModoPluginM ... cement.htm
Vertex displacement - can use any texture/procedural. Creates real subdivided geometry, so can be slow.
You can plug a mix texture directly into Vertex displacement, but texture displacement needs a baking node after the mix.
funk
Postby Dingbat » Fri Feb 18, 2022 1:04 pm
Dingbat Fri Feb 18, 2022 1:04 pm
:oops:
got it working now thanks as always to you both
Dingbat
Return to Foundry Modo
Fri May 10, 2024 3:39 am [ UTC ]
