How to make ACES color space work?
Forums: How to make ACES color space work?
Re: How to make ACES color space work?
Postby funk » Thu Sep 09, 2021 2:09 pm
funk Thu Sep 09, 2021 2:09 pm
Hesekiel2517 wrote:Hey there, i really like the look of the aces view in octane. Saving images as exr also works great, but when i try to save to png the colors are always wrong. How can I save the image to png?
Hey Hesekiel2517, I don't recommend PNGs but this is how it's done.
In the Save image popup use:
- save format = "PNG 8bit" or "PNG 16bit"
- color space = "Output - sRGB"
Make sure you pick "Output - sRGB" from the long list... Dont use "sRGB" (which is the default)
That will bake the ACES tonemapping into the png
Win10 Pro/ Ryzen 5950X / 128GB / RTX 4090 / MODO
funk
Postby elsksa » Fri Sep 10, 2021 7:21 am
elsksa Fri Sep 10, 2021 7:21 am
Hi Hesekiel2517,
in case anyone is interested and was not aware, shameless-plug: viewtopic.php?f=30&t=77601&p=404119#p404119 as some are using ACES just for its "look" (RRT from the ODT), there are much simpler and better-suited solutions for equivalently pleasing results.
elsksa
Postby Hesekiel2517 » Tue Sep 14, 2021 9:38 am
Hesekiel2517 Tue Sep 14, 2021 9:38 am
Hey there,
thank you for your answers!
@Funk: Sometimes I need a quick fileexport to show the result to the client. Exporting as Exr and converting this to a jpg is a little over the top for this. So exporting a png works great. Your suggestion gives a close result, but it's not the same as in the viewer. Do you get the same colors?
@elsksa
Thank you for sharing your knowledge! Yes, this seems to be a better option for me. I already had some problems using aces and it's really hard to understand how everything works :-)
Hesekiel2517
Postby funk » Tue Sep 14, 2021 10:03 am
funk Tue Sep 14, 2021 10:03 am
Hesekiel2517 wrote:@Funk: Sometimes I need a quick fileexport to show the result to the client. Exporting as Exr and converting this to a jpg is a little over the top for this. So exporting a png works great. Your suggestion gives a close result, but it's not the same as in the viewer. Do you get the same colors?
What are you using in imager > ocio view? If you set it to ACES:sRGB, those export settings should match.
Show screenshots of your settings if you're still having issues
funk
Previous
Return to Foundry Modo
Users browsing this forum: No registered users and 18 guests
Fri Apr 26, 2024 7:04 am [ UTC ]
