How to make ACES color space work?
Forums: How to make ACES color space work?
Postby kostache » Tue May 11, 2021 8:09 am
kostache Tue May 11, 2021 8:09 am
Hello,
could anybody explain me how to make ACES color space work in latest Octane for MODO? Where to take a proper config.ocio file? If I set my ones (v1.2 or v2.0 - they're taken from here: https://github.com/colour-science/OpenColorIO-Configs/) in MODO Preference for Octane I still couldn't choose available in menu ACES2065-1 or ACEScg as my Color Space preset for EXR saving option. There is also no any ACES presets for "OCIO view" and "OCIO look" in Imager tab. It will be great if someone could write step by step tutorial how to do that.
Thanks in advance
Konstantin
kostache
Re: How to make ACES color space work?
Postby face_off » Tue May 11, 2021 9:52 am
face_off Tue May 11, 2021 9:52 am
Hi Konstantin
This is a known issue, which I am waiting to hear back from OTOY on.
Postby funk » Thu May 13, 2021 6:48 am
funk Thu May 13, 2021 6:48 am
To see ACES working in the viewport:
1. Stop the render if its in progress
2. Go to system > preferences > rendering > octane and set the OCIO config filename to "C:\YOURPATH\OpenColorIO-Configs-feature-aces-1.2-config\aces_1.2\config.ocio"
NOTE: Make sure "Automatic intermediate color space" is enabled.
If you are using an older build that doesnt have this, set Intermediate color space OCTANE = "ACES2065-1" and OCIO = "ACES - ACES2065-1"
3. Set Camera > imager > OCIO VIew to "ACES: sRGB"
4. Start your render
Saving out ACEScg EXRs doesnt work correctly at the moment (which is what Paul is talking about in his reply), but will be fixed in newer builds.
Win10 Pro/ Ryzen 5950X / 128GB / RTX 4090 / MODO
funk
Postby kostache » Mon May 17, 2021 12:57 pm
kostache Mon May 17, 2021 12:57 pm
Hello Funk and thanks!
I just tried to follow your steps in case to make ACES work, but failed:
I have a MODO 14.2v2 and latest Octane build installed (2020.2.3.171). My render is hanging at the first sample if I going to use OCIO view with "ACES:sRGB" or any other from the long list there, except "none:sRGB". Right after I set it back to "none:sRGB" everything is run smoothly.
Konstantin
kostache
Postby kostache » Tue May 18, 2021 12:14 pm
kostache Tue May 18, 2021 12:14 pm
Hello Everybody,
an update - I tried to render with ACES 2065-1 color space as intermediate one (without any OCIO view option enabled, because of render hanging) and my render performance was decreased on 30% in comparison with regular render. My test time was 5.11 for normal render and 7.32 when I used config.ocio with ACES 2065-1 color space. Saving to .exr with ACEScg preset is working well, but result is unpredictable, because there is no chance to observe any changes on the screen so far (ACES to sRGB preview is hanging). I read, that OCIO v2 will bring faster color conversion speed, but I didn't find any workable OCIO v2 configs yet. Could anybody test same things on his own system and write a feedback?
Thanks in advance
Konstantin
kostache
Postby funk » Tue May 18, 2021 2:34 pm
funk Tue May 18, 2021 2:34 pm
kostache wrote:Hello Funk and thanks!
When this happens, open the octane log window and see if there are any errors
funk
Postby kostache » Wed May 19, 2021 6:01 am
kostache Wed May 19, 2021 6:01 am
Hello Funk,
yes, I've got some errors:
device 0: Failed to build OCIO LUT: OCIO error: The specified file reference 'Log2_48_nits_Shaper_to_linear.spi1d' could not be located. The following attempts were made: B:\Common\Libraries\Material\OCIO\luts\Log2_48_nits_Shaper_to_linear.spi1d
device 1: Failed to build OCIO LUT: OCIO error: The specified file reference 'Log2_48_nits_Shaper_to_linear.spi1d' could not be located. The following attempts were made: B:\Common\Libraries\Material\OCIO\luts\Log2_48_nits_Shaper_to_linear.spi1d
Konstantin
kostache
Postby funk » Wed May 19, 2021 6:12 am
funk Wed May 19, 2021 6:12 am
Have you actually extracted the zip to "B"? It looks like you're missing files from the ACES download.
Make sure you download the release zip file and extract it correctly (keeping the folder structure).
https://github.com/colour-science/OpenC ... s/releases
You need OpenColorIO-Config-ACES-1.2.zip
https://github.com/colour-science/OpenC ... ES-1.2.zip
funk
Postby kostache » Wed May 19, 2021 7:05 am
kostache Wed May 19, 2021 7:05 am
I found a reason - some file's access restriction.
Thanks Funk!
Konstantin
kostache
Postby Hesekiel2517 » Thu Sep 09, 2021 1:39 pm
Hesekiel2517 Thu Sep 09, 2021 1:39 pm
Hey there, i really like the look of the aces view in octane. Saving images as exr also works great, but when i try to save to png the colors are always wrong. How can I save the image to png?
Hesekiel2517
Next
Return to Foundry Modo
Users browsing this forum: No registered users and 21 guests
Fri Apr 26, 2024 9:13 am [ UTC ]
