VDB instancing - Artefacts
Forums: VDB instancing - Artefacts
Postby jtmsf » Wed Jun 12, 2019 12:14 am
jtmsf Wed Jun 12, 2019 12:14 am
Hi
I was experimenting with tiling a .VDB volume to see if it was possible to make a cloudscape using VDBs inside Octane for MODO.
Imported a single .orbx proxy to a mesh, replicated it using a particle generator, changed scattering and resolution inside the "edit proxy", and made a test rendering
Really bad artefacts in the intersection of the VDB replicas
Tried different volume resolutions. Same thing.
Is there any workaround or it's a limitation?
Thanks for any help
OctaneRender for Modo 4.04.0.145
Windows 10
Driver version 417.22
Geforce 1070 Max-Q
MSI GS73VR 7RG
jtmsf
Re: VDB instancing - Artefacts
Postby face_off » Wed Jun 12, 2019 12:27 am
face_off Wed Jun 12, 2019 12:27 am
Hi - may I suggest exporting the scene to Octane Standalone, and if the problem happens there too, submit the scene to OTOY in the Octane Standalone thread where they can investigate.
Postby jtmsf » Wed Jun 12, 2019 11:31 am
jtmsf Wed Jun 12, 2019 11:31 am
Thank you for your help
Just a quick update. I made more tests with different resolutions and settings. This was the result
Before VDB intersection
After VDB Intersection
Exported to Standalone, same issue.
Will submit a request to Standalone team as suggested.
jtmsf
Return to Foundry Modo
Users browsing this forum: No registered users and 19 guests
Fri Apr 26, 2024 4:28 am [ UTC ]
