Nodegraph multiple Outputs and Animation
Forums: Nodegraph multiple Outputs and Animation
Postby Hesekiel2517 » Wed Oct 11, 2017 12:56 pm
Hesekiel2517 Wed Oct 11, 2017 12:56 pm
Hey Paul,
i have an animated Environment (.exr Sequence) which is connected via a nodegraph to the environment colour. In the 3.6 version of the Plugin this works flawless. The 3.7 version loads the right frame at first but then jumps to frame 1 (i attached a video). The exported Ocs file works well though. Also plugging the animated Texture in a (for example) slot of a Material works.
Also in Octane you can create multiple Nodegraph Outputs. Modo seems to be limited by one output. When I add another output i get an error and can't edit the nodegraph anymore.
Do you know a solution to this?
Animated_Environment.zip
(21.66 MiB) Downloaded 135 times
Hesekiel2517
Return to Foundry Modo
Users browsing this forum: No registered users and 22 guests
Sat Apr 27, 2024 3:41 am [ UTC ]
