Modo constantly crashing on GTX 1070
Forums: Modo constantly crashing on GTX 1070
Postby tonisva » Fri Jan 13, 2017 10:56 am
tonisva Fri Jan 13, 2017 10:56 am
I just got octane for Modo 10, and I cant seem to get it to run smoothly. I get crashes every few minutes (Modo error screen and error report, then exit)
I am running Nvidia GTX 1070, I have tried many different drivers, Different versions of modo and octane. (Modo 701 and Modo 10). The crash usually happens when moving something around the scene or changing some parameters.
I read about changing the timeout values for the graphics card, but have not figured out how to do it, maybe this will solve the issue. - I am running Windows 10.
I also tried running octanebench, but get the error no compatible GPU - which is wierd.
tonisva
Re: Modo constantly crashing on GTX 1070
Postby face_off » Fri Jan 13, 2017 11:09 am
face_off Fri Jan 13, 2017 11:09 am
Which version of the plugin are you running? Which Nvidia drivers do you have installed? Which version of Modo 10 are you running? Have you tried deleting the modo .cfg file as per https://docs.otoy.com/manuals/products/modo/v3/installation-and-overview/troubleshooting/?
Postby tonisva » Fri Jan 13, 2017 11:29 am
tonisva Fri Jan 13, 2017 11:29 am
I am running Modo 10.2v1, Octane 3.03.3
Currently running Nvidia .375.95 But I have tried several different ones, including the latest one.
I have deleted the Modo.cfg file.
I am not sure if the documentation is old, or something wierd is going on with my software, but under the octane Kernel Settings Animation, I dont have the Load All Frames Into Octane button.
Another possible cause is that I have previously installed a subscription version of the software on the same computer.
tonisva
Postby face_off » Fri Jan 13, 2017 11:38 am
face_off Fri Jan 13, 2017 11:38 am
Which release of the plugin are you running pls? If not the latest version - can you pls install it.
Regarding Load All Frames Into Octane - yes, the documentation reflects the old system - pls see the release notes at https://render.otoy.com/forum/viewtopic.php?f=34&t=55078 for details.
Postby tonisva » Fri Jan 13, 2017 11:59 am
tonisva Fri Jan 13, 2017 11:59 am
I am running 3.03.3
tonisva
Postby tonisva » Fri Jan 13, 2017 12:06 pm
tonisva Fri Jan 13, 2017 12:06 pm
3.04.04 seems to be working well. was using 3.03.03 because it was the latest under "Licenses - Downloads".
tonisva
Postby face_off » Fri Jan 13, 2017 12:07 pm
face_off Fri Jan 13, 2017 12:07 pm
The plugin version is in the format X.X.X.X - you have provided the Octane release number, not the plugin release number.
Psul
Postby tonisva » Fri Jan 13, 2017 12:29 pm
tonisva Fri Jan 13, 2017 12:29 pm
The number under Modo-Octane Log is not plugin release nr?
tonisva
Postby face_off » Fri Jan 13, 2017 7:59 pm
face_off Fri Jan 13, 2017 7:59 pm
If you stop the render, the version number is displayed in the viewport render statistics. It's also displayed in System->Kit Toggle Enable, and it's also on the filename of the plugin installer. Regardless, you should have the latest TEST or STABLE version installed - detailed at the top of https://render.otoy.com/forum/viewtopic.php?f=34&t=55078.
Return to Foundry Modo
Users browsing this forum: No registered users and 20 guests
Fri Apr 26, 2024 7:46 pm [ UTC ]
