Hi Darren - you are right. I have look more at the tip2.abc file you sent me - and I cannot get it to render correctly in Octane Standalone. Do you have an OCS which renders that .abc file correctly pls?OK, tried via Open / File and it brings up the same options as Import which I was using. I can indeed bring in a single frame of the alembic animation this way, as you say it gets imported as a mesh layer with the render curves option.
However I need to bring it in as an animated sequence, so when I Open/Import it and select Import All Frames in the Alembic Load Options, it comes in as a non mesh layer, as in the previous screen grab I posted.
So as far as I can tell the problem remains, there is no way to load in an animated alembic sequence and have it render via the plugin? As mentioned the behaviour in stand-alone is as expected, it brings in the alembic per-frame with no bother.
Users browsing this forum: No registered users and 20 guests
